Thread Tools | Search this Thread | Display Modes |
#1 | ||
#2 |
Perhaps you didn't get the new 366 spring hooked up, or it wasn't hooked up perfectly and has come loose? That is my guess.
__________________
1984 Dodge Crewcab, D350, 1 Ton SRW, long box, 89 CTD, stock with 283K Kilometers, 366 spring, 1/8 timing bump, Fluidamper, Isspro Tach/Boost and Pyro Gauges, KDP killed, no I/C, piston lift pump, 2nd gen fuel heater, 3" exhaust, 96 NV4500 5spd with filter kit, Dana 60 with open 3.54's. |
#3 |
Had the same problem on a farm tractor when the gov spring broke, yep would be the same as the spring coming unhooked.
#4 |
did you put the tophat spring back on?
__________________
1992 W250 G360~ Wife calls it Satans' Lavatory |
#5 |
If the spring breaks or comes off it prolly won't even run. More likely you have the clocking wrong on the throttle shaft. Re-check your indexing on the shaft with the tick marks under the large allen nut. Most I've heard of are something like 4 down 1 up. I set mine so I could feel the tension of the spring inside the pump and then went from there.
__________________
The Redneck Rocket....92 CTD 4X4, 37" military Goodyears on H1 Alcoas, A518 swap and new to me motor, HE341, custom built air box, Rip Rook 4" exhaust, 03 Dodge power seats, Super Duty raduis arm front suspension w/ 2.5" ICON progressive coil springs. |
#6 |
Unless it's untaxed, then it's red.
i agree on checking the indexing. i did played with mine once putting it one tick further and one tick behind where it should be and the idle was surprisingly far off. a tick mark early and it wouldn't idle, a tick too far and it spun well over 1k rpm
__________________
4" straight pipe, M & H timing spacer, DNR POT kit, DNR intake, S&B filter, gloss black frame, deep/vented trans pan, KDP killed, 1 ton shoes with 1 1/8" wheel cylinders, HE351CW, PS/IC, Grid heater MIA |
#7 |
If the governor spring falls off in a 1st gen, the truck won't run.
It's an indexing problem or you put the fuel screw back in a little too deep.
__________________
Faith '93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air! Dead KDP's = 72 |
#8 |
Okay checked the gov spring it is still in place, and the top hat spring was put back on previously. The fuel screw is turned out far enough so i guess i will have to play with the indexing. Thanks.
| Display Modes | |
