Truck will only idle
I have a '99 Dodge Cummins that has had the light on for about two days. Last night it suddenly died and when I restarted the engine it would only idle. There was no response to the throttle and the throttle cable in still in tact. Any ideas?
Administrator / Scooter Bum
Try following this procedure.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
It should get you back on the road for awhile.
You'll proably need to start looking for a APPS soon though.
I'm in the same boat.
forgive the administrator for not welcoming you to the site......... he's a busy man but following the procedure he listed should help..... fingers crossed.
It is the big sensor that the throttle cable hooks to on your engine
where the cable hooks...sometimes is covered with a plastic cover..sometimes not
it is located directly above the VP44...and I believe is mounted with 3 bolts
Originally Posted by Road Work Ahead
Dumb question but what is an APPS?
Pedal
Position
Sensor
24 valve engines are fly-by-wire, no physical connection between the go-fast pedal and the engine,
computer does everything.
phox
Burning Oil
08-01-2010 04:09 PM
Dufrain
06-06-2004 04:24 PM
Paradise Racing
12-12-2003 03:22 PM
