Thread Tools | Search this Thread | Display Modes |
#1 | ||
tripple or single disk TC
__________________
2004.5 BLUE Quad Cab Long Bed 4x4 35-12.50-17 Interco Vortracs on H2's 2" leveling kit Airlift Rear Bags Diablo Predator Raptor 150 Quad Boost Fooler 5" MBRP Turbo Back AFE drop in Phantom boost, pyro, trans Lockup Switch UNITED STATES MARINE BY CHOICE, TEXAN BY THE GRACE OF GOD. |
#2 |
Kevin, Call Dave at Goerends www.gbtransmissions.com or Bill or Stephan at DTT www.dieseltrans.com and ask the same questions of both. Then you can make up your mind as to which one you want and need.
Tom
__________________
SUPPORT OUR TROOPS '96 Ram 2500 2wd auto, EGT, boost, & tranny temp gauges, timing at 16.5*,BHAF, #8 fuel plate slid 3/4 forward, AFC 3/4 forward too, Piers upgraded turbo, kdp tab fixed, Goerend Tranny, 15" long glass packmuffler, set up for 24' '06 Dutchmen 5th wheel and 16' boat behind 299HP 678TQ -U/A local 11- |
#3 |
Im pretty much looking for experience to talk not some vendor. Anyone with some realworld experience with the two products please chime in. Not to knock any vendors but I would like to know how these two options work in the real world. Thanks.
Kevin |
#4 |
I would do a multi.
You can pick up a good multi for a good price if you look hard enough. You do not need anything special to run a multi. I think stator configuration (stall speed) is the most important part of deciding what converter to use. Justin
__________________
2001 4x4 2500 SB QC. Bright White. HX40/35 BHT3B Twins, Guages, DT Trac Bar |
#5 |
I'm running a single and it is fine. It has a tight stall speed.
I don't want more parts in the trans to possibly fail. Keep it simple. Build the trans right, as a package.
__________________
2005 4 door 4X4 6 speed. |
#6 |
I think a single disk is fine to about 450hp. I had a Sun Coast Pro Loc Single and it did great for a lot of miles. I went with a triple when I knew I was going above that.
Stator design is always talked about and is usually mentioned in favor of one vendor in particular. I can tell you that Sun Coast can build them just about anyway you wish, but for daily drivers, Joe Webb has guided me in the right direction everytime, especially with 12v's. For racing applications, he has built whatever he has been asked to build. IMO - I would not go with a real tight converter with a 12v. If your truck is like most 12v's, it will shift very quick into gears with the extra power. A real tight converter will cause it to pull down, lag, and smoke. A balance between tight and factory is what I looked for, and I got it with a Pro Loc 44. Just my opinion for my personal taste in driveability.
__________________
David Dunbar 1998 Dodge 2500 12v - 370's, HTT Super Stock SS |
#7 | |
Quote:
I ran a suncoast single for 20K before I started building multi's. I was running high 13's before it let go, I was also running a very low stall sheet metal stator. The stall was great for the track, but when you are sitting in traffic with the a/c on it is very hard to control smoke. It was a pain to tow with also. Forget about backing up a load on an incline if you are running a low stall stator. And again, spool up time and stall are all a matter of personal preference. A lag pig to one could be a lightning fast spooler to another. |
| Display Modes | |
