Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 11-17-2011, 03:06 PM   #1
ataac_flat04
Question Transfer Case Clocking?
On my Crew conversion I am trading the Getrag for a 6 speed Allison automatic. On the donor club cab the transfer case hung down at an angle on the passenger side. If I remove one stud from the TC, I can bolt it directly to the back of the Allison. The problem is when bolted on, the transfer case sits level (instead of clocked down). My question is, will I have front drive shaft problems from the increased driveshaft angle? Will the double Cardan joint at the transfer case handle the increased angle? Or do I need to call up advanced adapters and get a clocking ring for the transfer case? TIA -Chuck
ataac_flat04 is offline   Reply With Quote
Old 11-17-2011, 06:53 PM   #2
sooty
sooty's Avatar
try it, and if your angle is giving interference, you can change the output front yoke, and d-shaft yoke, to a 1410, more angle you need anyway, much stronger where it needs to be, and eliminates the cardan joint.
__________________
1990 w250, he351cw, 40psi, f-pin/gov sp, max pump, 5x12's, 2nd gen i/c, nv4500 4x4, gv-od, rear disc brakes, later cooling system, straight pipe, coolertubz, 70 gals, 4wd popup camper, toilet/lots of water, zena welder, onboard air, big winch, 1500 wt invert,60 wt solar, optima,optima,fm tx(ham), custom storage bumpers, rr motorcycle rack, air bags, kdp, 2ND CUMMINS, 1963 jeep j-200 4bt conversion, sm465-4speed, ord gear doubler, 3 stick, gv-od, 8 lug dana powerlock front and rear axles, winch
sooty is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
