The "out" line on my transmission is the kind that has a port in it. My truck came with an aux tranny cooler. In the port now is the thermostat for the aux cooler fan. I'm thinking about putting a tee on the line port to add my tranny temp gauge sensor but I'm concerned about the extra weight hanging off the tubing putting too much stress on the tubing. <br><br>My other choice is to cut the same line where is flattens out just before the elbow that goes to the aux cooler hose and install a compression tee there. <br><br>Are the connections on the rigid tubing plain compression fittings or flaired fittings.<br><br>Comments welcome.
__________________
93 W250 LE, Extended Cab, Auto, 3.54LS 195,000Mi, Original Owner
ISSPRO Tran Temp, Pryo, Boost & Tach, f1 EDMs, Twins, aFe, Trans by DTT -89%, Borgeson, Full 4" Exhaust
