Thread Tools | Search this Thread | Display Modes |
#1 | ||
Tranny Temps
__________________
93 W250 LE, Extended Cab, Auto, 3.54LS 195,000Mi, Original Owner ISSPRO Tran Temp, Pryo, Boost & Tach, f1 EDMs, Twins, aFe, Trans by DTT -89%, Borgeson, Full 4" Exhaust |
#2 |
Re:Tranny Temps
Same here. 170* is normal from what i've seen and heard. Only when you are pushing it or towing do you see 200* or slighty above for a short time.<br><br>mark <br>PDR - Black Sheep Racing
__________________
98 -12v with G56 & SBC DD, Stg 5 twins, Cam, Dieseltuff 700cc p7100, Dieseltuff Taper Cut DV's, 90hp inj's, studed + O-ringed Stg 3 ported head, PacBrake. |
#3 |
Re:Tranny Temps
Jbolt-<br>Can't get mine to budge off of 180 for love nor money. It doesn't seem to care what the ambient temp. is or the load. Pulling my 22' construction trailer (7k) in mid-July still results in 180-190.
__________________
04.5 quad cab 4x4 auto, gauges, isspro turbo cooler, 315 BFGs, Smarty Jr. |
#4 |
Re:Tranny Temps
<br>cowpie- where is your temp semsor located? Mine is in the crossover line.<br><br>We are curently traveling and on the way up through the Sierras at night I was seeing almost 220 in OD and 200 out of OD and that was lightly loaded. 60mph average<br><br>We went up the mountain today after X-Mas trees and I forgot to take it out of OD. About 5 miles up a 6-8% grade I was at 250
Turned off the OD and it dropped back to 200 the rest of the way up. Seems high to me from what others are saying.
#5 |
DTR Online Store/Admin
Re:Tranny Temps
A lot of the tranny temp senders are located in the pan, if it is you may never know what the actual temp is getting to be inside that Transmission. The cool fluid is mixing in the pan and it will give you a false reading.<br> Your gauge may say 190 but the fluid could easily be 250 coming off the disks. You may be cooking that fluid and not even know it.
__________________
C.O.O. Diesel Truck Resource LLC To start a local chapter of DTR in your area email chapters@dieseltruckresource.com lellis@dieseltruckresource.com DTR Performance Shop Toll Free USA 1-877-375-1956 "We hang the petty thieves and appoint the great ones to public office." - Aesop |
#6 |
Re:Tranny Temps
The 96 has a torque converter lockup clutch and runs cooler. <br>The 93 does not have a torque converter clutch and runs hotter.
__________________
'97 SLT 2500, 4x2 LB Club Cab, 3.54 LSD, DTT 89% auto with Smart Controller, 230/605 fuel plate, 215 injectors, 3000 rpm GSK, AH1141 air filter, KDP tab, pillar mount Isspro gauges, Mag-Hytec, 5th wheel puller, 294 HP 2002 DD/MM |
| Display Modes | |
