Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 08-12-2005, 09:02 PM   #1
Geico266
Geico266's Avatar
Tranny jumping out of OD?
First time I ever noticed a problem. 50MPH, light throttle pressure, the OD seemed to slip in and out very quickly about 1 second then engage again. Fluid level dead in the middle, and its time for a flush, any ideas tranny guys?
__________________
"99", 265K on Original VP44 Before it Died.
300K miles And Running Strong!
2nd Full Goerend Bros Tranny & 3 Disc TC
Smarty, 2nd FASS HVLP95, ATS 3 piece exhaust manifold, 4" Exhaust, Fuel-Boost-EGT's, Sears Platinums, Marine 275's, K&N, 285's on stock rims, GMC 1 ton rear brake cylinder, Remote starter, KDP checked.
Now Driving A Ram 1500
Drive It Like You Stole It.
Geico266 is offline   Reply With Quote
Old 08-12-2005, 11:42 PM   #2
mamm7215
do a search on transmission problem or shifting problem. It's likely electrical noise, dirty battery terminals, low batteries, governor pressure sensor and/or solenoid, etc.
You'll find something. Could just be the hairy edge of overdrive and you're lugging the motor a bit.
__________________
GOT my 1st CTD :)
2002 SLT 4X4 Quad Cab CTD SB Auto SLT+. Moog track bar custom quad headlamps - Headache rack and aluminum bed caps, stainless nerf bars, Bilsteins all round, Dual Optima Red Tops.
mamm7215 is offline   Reply With Quote
Old 08-13-2005, 12:57 AM   #3
RATTLINRAM
RATTLINRAM's Avatar
You might try this,,, APPS Reset. It's free and may help.
__________________
*Dennis D. Tway*_____*1999 2500 SPORT QC*_____*Vice President-DTR Virginia Chapter#7*
2WD*Auto*3.54/LSD*Factory Loaded*Edge EZ*DDII's*BHAF*Wildcat -8AN SS Max Flow fuel system*MBRP 4"*CIPA Tow Mirrors
A-Pillar AutoMeter-EGT-Boost-Trans Temp*In-Dash Westach FuelPressure*55w Halogen B-U lights*Cool-Down Timer
Goerend Bros TC & VB + other goodies installed by VADTR Diesel Guru Tim Barber (Timinva)* 297.8 / 644.0 & 15.52 ET
*78 CJ5 *2002 Keystone 30' COUGAR 286EFS Double-Slide 5er*Harleys=77 FLHC*77 XLCR*79 XLS*
RATTLINRAM is offline   Reply With Quote
Old 08-13-2005, 09:13 AM   #4
Geico266
Geico266's Avatar
I did leave my lights on and drained the batteries pretty good just before this happened. I'll do the TPS reset also. Can't hurt.
Thanks Guys!
Old 08-13-2005, 12:34 PM   #5
Geico266
Geico266's Avatar
Quote:
Well, I tried that and I guess I did it too slowly. The first to second shift was at 3,000 RPM! Then I did the proceedure again and cycled the peddle in about 2 seconds. MUCH better. Pretty normal.
Question= Will the TPS "learn" a better shifting points or did this proceedure teach it something permenant? Is there a time that is specified for the correct shifting pattern?
Old 08-13-2005, 06:40 PM   #6
Extra300
My problem turned out to be the throttle position sensor. It didn't throw a code either but it was bad. I guess this is common. At least, replacing it fixed the shifting problems. Make sure that you have eliminated all other possibilities as it is a $450.00 part.
__________________
Money Pit :( 99 3500 dually 4X4 club cab long bed, white with black trim, 235000 miles, Rino full length step bars, bed mat and cap, Phenix Gold Amp and sub in a custom box with An Alpine head unit and MB Quarts coaxle speakers in the front and rear doors, K&N filter, Schaffer oil products, B&D digital fuel presure, pyro, and boost gages, B&D inline axilary lift pump with oil presure switch, rebuilt trany with shift kit and aftermarket tork converter, Superchips programed
Extra300 is offline   Reply With Quote
Old 08-15-2005, 10:42 AM   #7
barracuda
I dealt w/ that problem for a while, did all the normal stuff....APPS reset, battery terminals, etc. Finally I ran an extra ground from the PCM to the body and neg. terminal on the battery and it NEVER did it again. Mine was really bad w/ alot of accesories on, with the AC on it would jump out of OD at 60 MPH!
__________________
2006 3500 Quad Cab/DRW/4x4/Auto/SLT
Isspro Pyro,Boost and Fuel (I miss my 2nd Gen sound but that's about it)
Toys: 70' 383hp cuda' convertible
69' 440hp Super Bee
98' Vette
barracuda is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
