Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-27-2009, 01:56 PM   #1
dezlsmkr
dezlsmkr's Avatar
Tranny getting hot????
I have a 99 auto suncoast internals as the person I bought it from says the
problem is the tranny keeps gettin hot! Shifts great no slippage but when I get under it the cooling lines are ice cold what could cause this?? Once I get on th hwy it'll cool back down to about 179 or so but if I slow down or idle it'll jump to 230 in 2 minutes???? I am receiving these numbers via edge attitude monitor but when the minute gets 250 the factory trans temp light come on along with the O/D off light??? Any help would be wonderful?? Thank you!!
__________________
99 Reg cab 4x4. Suncoast tranny, edgejuice w/Attitude, 100hp injectors. Thats all i need!!
dezlsmkr is offline   Reply With Quote
Old 12-30-2009, 07:20 PM   #2
dozer12216
Sounds like the cooler lines are plugged. It could be anti drain back vavle installed backwards or plugged. The cooler could be plugged or a line bent. At any rate the cooler lines should be hot if run for any time. Especially the tube coming out of front left side of tranny.
__________________
2008 1/2 3500 dually that is stock except for 2 micro inline filter for fuel. Infero red extended cab, long box made for highway towing.
dozer12216 is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
