Trailer harness
Old 10-21-2014, 12:33 PM
bannerd's Avatar
Trailer harness
Where can I get a trailer harness for the W250? Any recommendations?
Old 10-21-2014, 01:48 PM
j_martin's Avatar
Maybe overkill for most, but good if you're concerned about electrical fire safety, adaptability, and failed circuit safe operation. Bonus is heavy charging circuit for the fiver and beyond.
https://www.dieseltruckresource.com/...e-t305370.html
Old 10-21-2014, 03:49 PM
cougar's Avatar
There are wiring harnesses that simply plug into your existing wiring harness in the back giving you all your necessary lights. They are fairly common and should be able to find one at any auto parts store or trailer supply store. As for battery and brakes, you can buy heavy gauge 2 conductor wire from the same place. Add some circuit breakers and your good to go. Not that hard to do.
Old 10-22-2014, 01:34 AM
Received 1,332 Likes on 862 Posts
This is what I did.
I used this one from Tow ready...or similar supplier... # 118317 . This plugs in to the factory wiring and gives you 4 pin lights.
Then I paired it up with a 7 pin trailer plug and harness, Tow ready # 20215 that accepted the 4 pin, and then had 4 wires to add to. One ground, one Batt power, and one from your brake controller, and a reverse light wire (I did not use that). Worked very well.
I PASS GAS
15
03-13-2005 02:53 PM
Leon441
01-13-2005 06:49 PM
Mechanos
12-21-2004 08:56 AM
1320
04-09-2004 09:33 PM
TPilaske
03-13-2003 04:06 PM
Quick Reply: Trailer harness
