Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 01-07-2007, 09:44 PM   #1
hoghead
hoghead's Avatar
towing skidsteer (tow rating)
I have towed skidsteer with my truck several times with no problems. I never gave a thought to how much weight i was towing until I went to buy my own trailer. I started researching the weight of the skidsteer (6000-7000lbs) and the gvw of the trailer (10,000-12,000lb) the trailer weighing about 2300 lbs and I dont think that factory gvcw for an automatic dually with 3.54 gears is rated for that kind of load but I would like to hear from real world experience with a first gen. also I need advice about the trailer to buy 10,000 lb or 12,000 lb the first of the 2 is going to be a little overloaded if I need to have a backhoe att. or a concrete breaker on the trailer as well as the skidsteer. I know I should post this in the towing section but I figured since we are a small portion compared to the 2nd and 3rd gen didnt figure my first gen brothers would mind.
__________________
92 d350 dually, 188,000 mi.,white reg. cab, factory slushomatic a518, straight exhaust, borgeson steering shaft,cheap tps fix
hoghead is offline   Reply With Quote
Old 01-07-2007, 10:07 PM   #2
unclemarc
unclemarc's Avatar
towing skidsteer
I have a tandem axle dump trailer rated at 14,000 gvw that I haul around a bobcat in,the truck seems to pull it around alright in town.The freeway is another question as I have not done the freeway trek just yet,although I think I need some help in the rear end {beefier suspension}if anyone has a suggestion I'm all ears. marc
__________________
1993 2wd ext.cab 4spd o/d asa modifieds intake stock straight pipe 167,000mi.,isspro 4k rpm tach
unclemarc is offline   Reply With Quote
Old 01-08-2007, 10:17 AM   #3
dpuckett
Go for the heavier rated trailer. I have towed 10-12K behind me with a stock auto with no issues. I have also grossed in the mid 20s regularly with a manual, and had no problems. Just accelerate and brake easily, make sure the trailer has 2 brake axles, and they are up to par.
unclemarc- yes, I have a suggestion- get a dually. That or some helper air ride springs, and a swaybar.
Daniel
dpuckett is offline   Reply With Quote
Old 01-08-2007, 07:24 PM   #4
hoghead
hoghead's Avatar
Just bought a 16' 12,000 lb Big Tex drop axle trailer with all wheel brakes this afternoon for $3700 I compared it to a cronkhite trailer (one of the best you can buy for a skid steer) and I was impressed with it. The salesman said that it is a model they have special made for their company to compete with cronkhite and after a side by side comparison the Big Tex was alot more solidly built more like a 14,000 lb. thank for the replies.
Old 01-08-2007, 08:36 PM   #5
janb
My Tracked SS is ~10,000# + accessories ~1200# each, (I usually take 4)
my trailer is rated 22,000# and weighs 5,000#
I often Gross 25,000+ and tow in mountains. (pic in my gallery)
1t W350, slushy a518 (I haven't installed my DTT tc yet, I really want a better suited truck for this application) preferrably a 'tandem hook lift' with a 10+ spd and jake. I'm always needing a dump for import and export of materials, and it would be really nice to have an extra hyd high flow source to run bobcat chipper (without adding hrs to machine)
__________________
'93 CTD 1T 4x4 flatbed,Case Crawler,Tracked Bobcat,12k# mini-ex 27...vw diesels - too many projects...
janb is offline   Reply With Quote
Old 01-09-2007, 04:10 PM   #6
hertz
Go ahead and tow it. As long as everything is secure and working properly do it. I'm a tick over with the trailer GVW while towing our skid steer. GVW on the trailer is 10,000 and our skid steer weighs 10,000
__________________
94Freightliner FL70 custom 32ft box conversion 12ft living quarters and 20ft garage pyro/tach/boost gauges pump rebuilt fuel screw all the way in, , PDR HX35 14cm gated, Bully Dog +50hp injectors. 4" straight exhaust,ARP head studs, piston style lift pump, 8* or 1/8" of timing. Soon To Be : 3200 gov. spring, HTBG turbo, everything port matched. have to put on: new head w/60lbs spring,HTT exhaust manifold, old smokey fuel pin is waiting for a new or rebuilt pump.
hertz is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
