Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 04-26-2007, 10:52 AM   #1
brainfade
brainfade's Avatar
Tough impeller change
In preparation for an impending stage IV install, I disassembled an old turbo I had floating around to see if there were any bug-a-boos. Everything came apart as expected except that after removing the left hand thread nut on the impeller, the pin wheel was really stuck to the shaft. After trying an assortment of non-destructive methods (PB blaster, heat etc.) I just drove the shaft out with a soft drift and a small hammer. This, of course, broke the wear plate under the impeller. No biggy, plate was worn out anyway. However, I don't want to damage the turbo currently on the truck, so my question is this: Is it normal for the pin wheel to be difficult to remove or was this an exception, and if the good one is sticky, what is a good way to remove it without damage?
Thanks,
Brian
__________________
'91.5 W250, G360, 4.10's, Big, Red and Stinky. Pyro, boost, BHAF, 16cm, pump lightly leaned on. Timing + 1/4 in. Now smoking with Stan's 4 in. turbo back and breathing with an HTT stage IV. Disks on the rear and Hydroboost in the works. "The mother of all parking brakes" on the driveline with 290,000 some odd miles. Hey, where'd those PODs go? Holy Cow! They're in the engine!
brainfade is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
