Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-03-2009, 09:49 AM
ironbutt's Avatar
ironbutt ironbutt is offline
Send a message via Yahoo to ironbutt
Tire Wear Problem
I recently wore out a set of tires on the front of my 02 dodge, It was aligned when they were installed in may. Tires wore out on the outside, but not on the inside. There is some mild cupping , but inside has no noticable wear. The truck tracks strait as an arrow, and under hard breaking there is no pulling to either side. Went back to the alignment shop and they said it was dead on to factory specks [ Hunter system] Any Ideas, ?????
__________________
2002 2500sport quadcab auto 354 gears,gauges,mag hytec,tranny&rear diff,powerpuck,str8 pipe4",bilstien's
,B&Wturnover.60 gal aux tank/toolbox combo,BHAF,vulcan SS fuel fittings and lines.In tank pump at 80k,165,000mi & pulling.Downsized to a TT from 5th whl.toy hauler
Old 11-04-2009, 11:00 PM
ironbutt's Avatar
Hey 24 hrs and no responce.
__________________
Old 11-04-2009, 11:25 PM
13ALPHA's Avatar
13ALPHA 13ALPHA is offline
No answer, but in my 00 I have the same issue, got alignment specs, they are good, but uneven wear on front tires. Bad ball joints?
__________________
Scott
Patriot Blue 2000 3/4 ton
NV4500, 285/75R16 BFG AT's, MBRP 5" exhaust, 2" leveling kit, ATS ARC-FLOW, ISSPRO's (boost, EGT, FP), BD Intercooler boots, GDP GFS392, AFE Stage 2, EDGE Comp, DDP Stage 4's, HTT 62/71/14, SB DD Clutch
New VP at 120k
For Alaska: Oil pan Heater,Trickle Charger, Block Heater, Moose Bumper
18FEB08: 521HP & 1110 ft-lb
torquefan's Avatar
torquefan torquefan is offline
With outside wear my first assumption would be that the wheels are toed in a bit. I should also mention that strangely, some brands of tire are more prone to showing this type of wear than others. It has mostly to do with cornering. Frequent rotations help of course, but without seeing the alignment printout (if there is one), or knowing their machine is in calibration, I can't say much else.
__________________
1996 Ram 2500 Club Cab, 4x4, 5 speed, KDP tabbed, Prodigy, Silverstars with relay kit, BD 4" cat back, Autometer gauges.
I've donated.
Old 11-05-2009, 01:37 AM
TNutcher TNutcher is offline
Send a message via AIM to TNutcher
how long were these tires in their locations to show that type of wear? Mine start to show slight cupping after about 8,000 miles so i try to rotate every other oil change or so. Even for these trucks having solid front axles, the way they're setup, they still wear odd. I think it is having to do with the fact that the hubs are engaged all the time, maybe locking hubs allowing JUST the wheel to spin seem to have better tire wear/ more true tracking without having to spin the rest of the axle during normal operation. Idk i'm just throwing this idea out there but it makes sense to me. Good luck
TNutcher
__________________
'99 Dodge Ram 2500 24v 4x4 - 165k, Suncoast AT, Drag Comp, Jammer 5s, Isspro Gauges, 62mm, Leveled, 285 75 17 Hancook AT on 17 Cheyenne 8s, LocknStitched 53
Old 11-05-2009, 07:33 AM
Redliner's Avatar
Redliner Redliner is offline
Outer edge ware on BOTH sides would be toe issue. We usually set them to around .08 Deg where the factory specs call for .16 - .20 Deg. If its just the outer on the right side its due to that wheel holding vehicle on the road due to road crown. NEED TO ROTATE EVERY OIL CHANGE OR 5000 MILES and air pressure must be checked. I usually set the fronts around 65-70psi. As far as choppy that would be worn shocks or lack of rotation both can contribute to this.
__________________
Mine: 2001.5 Ram 2500 4x4 QC, Long Bed, Patriot Blue, Edge Drag Comp, Full Billet Goerend (Hope it lasts), BD Special Turbo, Always changin somethin...
549hp/1093tq 07/11/09 on Dunbar's
just hit 198k on original VP44
Future Wife Lori: 99 Ram 2500, Quad Cab, Short Bed, Intense Blue, Powered by BD, Edge, Smarty, Fass and her hard right foot...
Old 11-06-2009, 01:33 AM
pind's Avatar
pind pind is offline
Rotation, or lack thereof, is the killer on fronts.
Being outer wear on both, I would tend to say you are toed out just a little too much.
RF outer wears fastest, and will cause all kinds of grief if not rotated properly or often enough.
Strange wear on the inside of one tire more than another, generally indicates a rear axle out of line, causing it to push in one direction or the other. See it more on highway trucks than anywhere else.
good luck
__________________
01 2500 Q/C 4x4, factory order HO w/5spd, 4 wheel discs, Pacbrake, 285 Cooper STT's on 058 Eagle Alloys. Ultra 5th wheel hitch. Glacier Diesel GFS-392 LP
01 F550 XLT 4x4, Jokestroke, 6 speed, heila knuckleboom, boxes and deck, low mount 5th wheel. No mods, no power, no fuel economy, kinda like a ford.... HAHA
Never judge someone until you've walked a mile in their shoes. Then, when you do judge them, you're a mile away... and you have their shoes
Old 11-06-2009, 03:21 AM
JasonblkZ06 JasonblkZ06 is offline
What would cause cupping on the front inside tires? I rotate, but they still eventually cup. It has been aligned.
__________________
2001.5 4x4, HO, 6 Spd, QC, 275RV injectors, 5" exhaust, Volant air intake, Edge Comp, Airdog 150, H2 wheels, 315/70R17 tires, Rancho RS9000s, Superlift front springs, 3rd gen front brakes, DSS.
Old 11-06-2009, 06:52 AM
Redliner's Avatar
Shocks cause cupping. Low air pressure causes cupping also.
__________________
Old 11-06-2009, 01:07 PM
01trailerpuller's Avatar
01trailerpuller 01trailerpuller is offline
Great diagram for tire wear. http://www.abbsrytire.com/diagramtire.htm
__________________
01 Cummins 4x4. Edge Juice w/Attitude, Airdog II 165, 40hp Edge jammers, what silencer ring, Byrd's Diesel intake horn, BD heavy duty auto trans with lockup, MBRP turbo back 4" with dual 4" black turn outs, Airaid cold air intake and Pacbrake EB.
Old 11-07-2009, 04:27 AM
Quote:
Shocks are new, air pressure is good.
__________________
Old 11-07-2009, 01:18 PM
SIXSLUG's Avatar
SIXSLUG SIXSLUG is offline
MIne was aligned twice and dead on according to the tech. The third time in they had gotten the machine recalibrated and my alignment was way off. They re aligned it and it has been good for about 2 years now.
Your problem sounds like excessive toe in. They steer better with a small amount of toe but a lot will wear out the outside edges like you are seeing.
Luck.
Kurt
__________________
2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Laramie Plus
Arctic White,3.54 gears, Camper/Tow, Stull stainless running boards, A.R.E. cab-hi canopy w/ SS Vanguard rack, Southbend clutch and hyd.,Power Service, BHAF/heatshield, MBRP 4" TBE, FP gauge, Femco E-Z drain plug,DSS, Thuren trac bar, 2" leveling kit, P/H tow mirrors, new intank LP @80K, 91K miles.
Next mod: Smarty, EGT gauge
Support Our Troops! NRA, MSBL, BYO
Old 11-09-2009, 05:45 AM
dozer12216 dozer12216 is offline
You would be well advised to have alignment set at near 0 toe in. Outside wear on both is definite indication of excess toe in for a individual unit. Just because the alignment shop says it's in the GREEN don't make it correct. Many techs do a better job with strings than others do with a $30,000.00 piece of equipment. Over size tires and agressive tread, or incorrect wheel offset will always make wear worse. Cupping can be affected by toe in.
I believe this is posted in wrong place for best results.
__________________
Big Blue Beast. 2000 SLT dually heavy towing auto 2WD, stage 1 injectors, 235K and still growing.
Goldenrod. 1984 Rampage with 2.5 1/2 liter EFI engine. D8H CAT dozer and old Hein Werner excavator. Retired to play with toys.
Old 11-09-2009, 12:17 PM
01RAMer's Avatar
01RAMer 01RAMer is offline
Quote:
Strings??? How are strings used in this process? Sounds like something anyone can do.
__________________
01.5 - 3500 Dually 5-speed, 4x4,
Egde Juice w/ Attitude, SS Track Bar, DSS, MBRP 4in Exh, Fuel Transfer Pump Retro ,2 WD Low Sw
Reese Gooseneck & 5th wheel Hitch w/ in bed elec connector
Elec Flip Tow Mirror Conversion, Mack Trk Air Horns
37ft 5th Wheel Montana 3400RL, 4 slids, Onan Genset, w/TrailAir Pinbox
Old 11-09-2009, 12:25 PM
larrybartlett larrybartlett is offline
are your ball joints ok? they can also cause tire wear issues
__________________
2001 1T Quad Cab 4X4, HTB2/62 Street Stock 12CM-62MM Turbo, Volant Air Box, Flowmaster Exhaust, Edge Juice w/Attitude, Goerend Auto, FASS 150 Fuel System, Ranch Hand Grill Guard, B&W Hitch, Monroe Shocks, Timbrens, Borgeson Steering Shaft, DSS Steering Stabilizer, CC Custom Tailgate, Waag Kickouts
A lot of good men have went to Washington, very few have left!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
