Thread Tools | Search this Thread | Display Modes |
#1 | ||
Tire Pressures
__________________
2002 Ram 2500, SLT, Patriot Blue/Grey, Quadcab, 4X4, shortbed, auto, Trailer Tow group, Camper special, 3.55 gears Anti-spin differential, ATP Wrap, Soft Tonneau cover, Auto-Vent Shade bug shield. Delivered 6-24-02. |
#2 |
Re:Tire Pressures
65 front<br>55 rear<br>Unloaded.<br><br>The best ride I have found considering the weight in the front end.<br><br>phox
__________________
2002.5 Dodge Ram 2500 4X4 SOLD 2009 Jeep Wrangler Unlimited X 4x4. Detonator Yellow in color Bone stock for now, at least for a couple months 2008 Harley Davidson FLHR Road King. Black Pearl in color 12 inch apes, stainless cables, Vance & Hines pipes, garage door opener, combo speedo/tach |
#3 |
Re:Tire Pressures
Same as above.
__________________
Y2K QC 4x4 SWB,3.54 LSD, Auto. , DTT, T.C.,V.B, DTT Smart Cont. Pac Brake. Edge-Comp, 275 RV's Auto-Meter gauges,AFE Mega Filter, 4"exh, Magna-Flow SS muffler. FASS fuel pump. Dynoed 365 rw hp. |
#4 |
Re:Tire Pressures
80 psi all around, because I like to load it up pretty good on occasion. I could run lower like the guys above, but the ride is pretty good now, and ride quality is the only reason to drop the pressure for on road driving. Running 235/85/16E's. For those running C's or D's, do not try 80 PSI, 65 psi max for D's and I think 45 for C's? Check the tire sidewall for max pressure to be sure.
#5 |
Re:Tire Pressures
65 all around
__________________
Former owner of an '02.5 4x4 QC SB, Lt. Almond, Auto, 3.55LS, DTT 4" exhaust, Westin Platinum step bars, Reunel rear bumper w/PIAA 40's Leer 100XL cap, Kaydenco mud flaps, Bilstein's, Mag-Hytec diff. covers, BHAF, Optimas, Garmin GPS V, Sirirus sat., Yaesu FT-8900 (I'm K3GM) Delivered 3/1/02 - 135,000 miles 2/15/07 Altogether now...."Happy trails to you.....until we meet again....." |
#6 |
Re:Tire Pressures
I run:<br><br>65 front, 55 rear, Unloaded.<br><br>When pulling the trailer, I run 70 front, 75 rear.<br>
__________________
2002, RAM 2500, 4X4, Std. Cab, 6-speed, HO, Patriot Blue, Swiss Patriot Lid, Westin Platinum Step Bars, Manik polished stainless brush guard, KC Highlighter 130W halogen driving lights (X4), Hella 550 fog lamps, auxiliary backup lights, Custom expansion fuse/relay panel, Custom lighting switch panel in overhead console, VentShade's, Missing/stolen turbo silencer ring, Magellan MAP 330 GPS, Cobra 29-WX-NW-ST CB, Twin 4' Firestick antennas on back of cab, Di Pricol Pyro (with blue LED warning light)/Boost/FP gauges in pillar mount, Isspro Turbo Temp Monitor (delayed shutdown), 4" Banks Monster Exhaust SS exhaust minus the muffler, PacBrake (modified for enhanced electronic control), Edge EZ, Lund Screen Front grill/bumper inserts, Rancho RS9000X shocks with dual remote, 2" front lift/leveling kit, RV275/300 injectors, BFG KO T/A LT295/75R16/D on stock alloys, DynaBeads balancing from Innovative Balancing, Heckethorn HD steering damper, BHAF w/Outerwears waterproof pre-filter, Big banjo fittings from Wildcat, Redline Synthetic in all gearboxes, Larry B's Stainless Heat Shield, South Bend Clutch MU 1947 CON OFE. Other toys: Honda Foreman TRX450SE '54 Ford 640 tractor (restored) "Don't need no stinkin' spark plugs" |
#7 |
Re:Tire Pressures
65 all around unloaded rides good , towing 5000 lb trailer rears looked low upped to 70psi looks better.towed at both 65 and 70 in rear no difference in handling , just liked the way tire looked with 70 in it better
__________________
New Truck 2010 Mega Cab 2500 6.7 Cummins , Mud flaps , Dodge aluminum running boards , Bed Rug , Ranch bed cap OLD TRUCK 02 4x4 Dually Auto 4:10 Mag-Hytech Diff Covers And DD Trans Pan.Edge Ez..No Silencer Ring Scotty II.Cool Down Timer.Painless Wiring Kit.Brakesmart Brake Control.Power Flip up Towing Mirrors.Rhino Liner.Added Factory Fog Lights.Power Locks.JVC 12 Disc Cd player.Nerf Bars.Di-Pricol Gauges,(egt,boost,tranny temp) Westach electric FP gauge.Halogen Back Up lights |
#8 |
Re:Tire Pressures
Thanks for the input guys. ;D Nothing like first hand experience. Right now I have 70 all around and it rides a little rough.
I think I'll try 65 front and 55 back unloaded and 70 all around loaded with the camper. Later. 8)
#9 |
Re:Tire Pressures
I run 70 in the front and 80 in the back with E load tires.
__________________
97 Dodge Ram 2500 ClubCab, Long Bed, 4X4, CTD, Auto, 3.55, Yokahama Geolander HT, Rancho 9000x, Putnum Lock n Load Gooseneck, Pace Edwards Roll Top, Mag-hytec tranny and diff pans, Prodigy, 120K miles and 10 Disk CD changer. 01 Trail-et 2 Horse Slant Load Gooseneck with Weekender package. (7500lbs - two horses) |
#10 |
Re:Tire Pressures
Mine truck came with only 50 psi in the tires and the outside edges started to 'feather'/uneven wear after a couple thousand miles.. I bumped the pressure to 60 all the way around and they appear (to the unprofessional eye) to be wearing evenly now..<br><br>I really didnt see that much of a deteriation in ride with the 10 psi increase either..
__________________
2002, 2500 Quad Cab SLT, 24V CTD, Lt. Almond, 4x4, SWB, A/T, 3.55 w/ Ltd slip, Ameriguard spray in bedliner, Stainless Go Rhino wheel to wheel side steps, EZ change drain plug, everything else stock. What I'm pulling: 2002 Flagstaff 823 popup and a John Deere 790 compact tractor - 4x4, FEL |
#11 |
Re:Tire Pressures
80 psi in front & back 02 3500
#12 |
Re:Tire Pressures
If you look in the owners papers in the glove box, there should be a tire pressure sheet. I run 55-57 Front and 42-44 rear empty. With the 5er I put the rear up to 65. If you leave the rear pumped up empty, it really has an adverse effect on handling and ride. SNOKING
__________________
2001.5 2500 STD CAB AUTO SLT 4x4, 4:10's LSD Pattriot Blue, Camper and Trailer packages. Banks brake and gauge set, PDR35W12, Comp, Full DTT with smart controller and Billets. DD Jammer 1's, 4" Magnaflow SS exhaust. NAPA 6637 BHAF with outwears. Highjacker 16K 5th wheel hitch, Cardinal 29WBLX (18.2K combined weight). |
#13 |
Re:Tire Pressures
3500 4x4
#14 |
Re:Tire Pressures
And more:
#15 |
Re:Tire Pressures
OK, for you 2x4 2500's.
| Display Modes | |
