Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Big Rigs
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 10-22-2009, 10:05 PM   #16
deerslayer1979
Did anyone mention wrapping a chain around the whole assembly? That is what we were told to do in school, not sure about airing them down, but I would not want to mess with any split rim that was still aired up and not restrained with chains or straps.
DS79
__________________
1992 W350 DRW NV4500 4.10 gears. Fuel screw turned 3 turns, pin turned and washer removed, 16cm housing, boost and pyro gauges Alum. flatbed with hidden goose neck.
deerslayer1979 is offline   Reply With Quote
Old 10-25-2009, 09:39 AM   #17
DetroitDiesel71
DetroitDiesel71's Avatar
Location: Dayton, NJ (temporarily while In USCG on Staten Island)
well I got the job done, thanks for all the advice and help. After closely inspecting split ring rims, I saw what bad shape they were in and how dangerously wore out they were. Here are a few pics of job
Click image for larger version
ID:	30051  Click image for larger version
ID:	30052  Click image for larger version
__________________
2001 CTD 2500 4x4 Ram sport,RED, 5 in Twin Turnout stacks, BHAF custom built intake, custom built 16 gauge pod panel, where the cup holder went.RV275s, Goerend Tranny and triple disc converter, 285 BF A/T KO's,XM radio,CB, 245,000 original miles, orig IP,3rd L/P Original Owner from Day one.
1972 Brockway K361TL with a screaming detroit 8v71
US COAST GUARD Staten Island NY(not by choice)
SEMPER PARATUS
Originally from Angleton Texas. " Last Of the Detroit Diesel Loving Men"
DetroitDiesel71 is offline   Reply With Quote
Old 11-29-2009, 06:04 PM   #18
PeytonMaterne
PeytonMaterne's Avatar
So spoke wheels will accept either 10x20s or 11x22.5s. My 54 GMC has 20 inch tube tires and I would like to go to 22.5s. I thought I would have to change the spoke/hub portion to accomplish that but I guess all I need is modern 22.5 rims and tires then?
__________________
#1, 91.5 D250, getrag, 3.54s, 204k, a few mods, it'll get out of it's own way
#2, 91.5 D250, auto, 3.54s, 201k, minimal mods,21-23mpg
#3, 84 D150 shortbed steppy,5.9,727-3.07s(powertrax no-slip),pods, piston pump, DennyT-II,3" crossover, icebox intake,60mm gds, 18.5, 315/60/15 drag radials
PeytonMaterne is offline   Reply With Quote
Old 12-01-2009, 05:24 AM   #19
DetroitDiesel71
rim sizes
Peyton, yea I converted from the old 11x20 split ring to a new rim which was non split ring 8.25x 22.5 with a 11 x 22.5 tire. I got the rims for $30 dollars including blasting and powder coat. The job was easy, just took time and all the advice given here. Now on to the rears....lol
Old 12-01-2009, 10:48 AM   #20
PeytonMaterne
That's good news then, I can get some modern rubber on the front of the truck. Did you buy your rims locally? That sounds like a good deal. Oh, and I love detroits too.
Old 12-01-2009, 11:30 AM   #21
DetroitDiesel71
yea I got them from F and S tire in edison NJ. Huge inventory of good used rims, just pick out the ones you want, they blast and powder coat before mounting them for me. Took three days from purchase to pick them up. Just threw in bed of truck, and hauled to base to change them out.
Old 12-01-2009, 01:15 PM   #22
Nick02Ram
Not to run this safety thing into the ground, but a guy not far from us was just hospitalized in a drug induced coma. He was airing up an Ag tire, and somehow (we've heard tons of rumors) the bead blew off and basically rearranged his face. The odds of anything like this happening are few and far between, you have a better chance of being hit by an oncoming vehicle mounting the tire than you do airing it up...but its best to play it safe. After this happened, our bosses all had a meeting with our 3 shops, and basically said if anything unsafe is being done, you are fired on the spot. Most of the stufftakes a lot more time than usualy, and its a bit of a pain, but I suppose its better than having my nose repositioned into my ear.
__________________
02, 24v, 6 speed, Edge Juice w/ Attitude, BHAF, 5" exhaust to dual 7" turnout stacks, 35" Pro Comp Xtreme AT's, silencer ring removed, 1700 watt stereo, XM radio, CB, Eaton Fuller shift knob, Fuel Boss Mechanical Lift Pump, on board plug in jumper cables
Nick02Ram is offline   Reply With Quote
Old 12-04-2009, 10:20 PM   #23
Haulin_in_Dixie
Haulin_in_Dixie's Avatar
Not mentioned here but I have had a split ring seperate on the front wheel at 80 plus mph. Not fun. Crazy I was able to use the tire, did not hurt it, just had to chase it. I was in the middle of a line of trucks in SC heading home, they sold a lot of underware at the next truck stop but no one was hurt.
__________________
99 2500 4X4 Laramie Quad cab ISB275 engine 660 tq stock with air comp, HX35/18.5, NV5600, 13.125 SBC, 354 posi, Rancho 9000, Scotty II, EZ, FASS, bottom feed, ported ATS ex man, Isspro gages, Truspeed, Ford dual wheels, Jorden, Alpine, amp, M15000 warn.
Freightliner Condo, N14 500hp.
Kaufman EZ loader VI car hauler
97 Dodge 2500, Club cab, 4wd, tow body, cow catcher, 12v, NV4500
Borne 50’ car hauler
53/102 Trailmobile Reefer
Haulin_in_Dixie is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
