Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-06-2002, 01:19 PM   #1
CWICKHAM
TIMMING 24 VALVE CTD.
HOW DO I CHECK THE TIMING ON MY 24 VALVE 98.5? <br>MY BROTHER HAS A 99 IT IS SMOOTHER, QUIETER &amp; MORE POWER. THANKS
CWICKHAM is offline   Reply With Quote
Old 12-07-2002, 07:45 AM   #2
PourinDiesel
PourinDiesel's Avatar
Re:TIMMING 24 VALVE CTD.
The Timing on your 24valve ISB is electronic.<br>Your Crank, Cam and Fuel pump gears are zeroed with each other at the factory when installed and your fuel pump has a tooth (pump specific) that is timed to the gear train/assembly.<br><br>I would start with checking fuel pressure from the lift pump, a weak or dead lift pump will cause a crappy idle and low power.<br><br>--Justin
__________________
123456
SMARTY POWERED!!
PourinDiesel is offline   Reply With Quote
Old 12-07-2002, 08:19 AM   #3
CWICKHAM
thanks,,if i take the plug out of my fuel filter,can i check lift<br>pump pressure there? should the pressure be 6psi or higher<br>constantly?
Old 12-07-2002, 09:08 AM   #4
rich
rich's Avatar
I believe pre filter pressure should be around 12 to 14 at idle and around 6 to 10 running at around 2000 rpm. I went from an 01 to 98.5 and to me they sound a little different why I dont know but they do. Little bit more motor noise. If you do need a lift pump get it from cummins and not from dodge. Better price and better warranty, mine was 160.00 and has 12/100k warranty. They are not that hard to put in. It took me about an hour and I even put in the banjo kit from wildcat.
rich is offline   Reply With Quote
Old 12-07-2002, 12:51 PM   #5
CWICKHAM
thanks
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
