Thread Tools | Search this Thread | Display Modes |
#1 | ||
Things to do to the motor while I have it out
__________________
1992 Dodge 250 2wd Auto reg cab long bed w/90k miles 1993 Dodge W250 4X4, club cab, long bed, getrag 5 speed w/240 miles, piston pump, stans full 4 inch, hx35 w/ 12cm housing and banks big head waste gate actuator |
#2 |
Id recommend maybe stuffing a new camshaft in it.
__________________
1970 war wagon with small dents '90 cummins,with to many mods - needs more power again |
#3 |
Change the oil pan gasket, the rear main seal, front seal(when you do KDP) and check carefully for any other leaks you may have. Upgrade the fan(someone said dodge came out with a more efficient fan type) the belts, T-stat, and all your hoses(every one of them). If you plan on putting in guages, depending on type, plan ahead if there are any tough spots to get to for sensor installation.
Oh, yeah, paint the engine!!
__________________
1993 W250 AUTO. MODS: 3200 G-SPRING- 2 TURNS ON FUEL SCREW. PLUNGER LP. PODS. DTT TRANNY. PDR HYBRID HX35 16CM2. SMOKEY PIN. STAN'S 4" EXHST. TRANNY COOLER W/ FAN & T-STAT. AUTOMETER BOOST, PYRO, FUEL/OIL PRESSURE, & TRANNY GUAGES. ISSPRO TACH. FILTER MINDER. MAG-HYTEC TRANNY PAN/DIFF COVERS. BULLYDOG/ATS PROPANE & SNOW'S WATER INJECTION #2. COOL DOWN TIMER. HTT 3 PIECE MANIFOLD. AUX.TRANNY & COOLANT FILTERS. KDP TABBED. 5" INTAKE. 7.3 PSD I.C. 3" COOLERTUBZ |
#4 |
Great Recommendations
I didn't do all of the above , just the bare minimum... I had to get it out of the garage and into the crew. I have been traveling so much I didn't have time to do all that stuff. But yeah check for leaks. Definitely Front and Rear Crank Seals.Fans and belts can go on anytime, hoses.. But if you wanted to do a pan gasket that would be the only time to do it... Paint and dress n polish would be bling yah. Pyro drill for the manifold yes...
__________________
2012 3500 CCLB SRW G56 4x4 1973 Ford Courier Crawler |
#5 |
If you have any plans for a piston lift pump it would be easier now rather than leaning over the fender. Otherwise it's a pretty good list so far.
__________________
'91.5 W250, G360, 4.10's, Big, Red and Stinky. Pyro, boost, BHAF, 16cm, pump lightly leaned on. Timing + 1/4 in. Now smoking with Stan's 4 in. turbo back and breathing with an HTT stage IV. Disks on the rear and Hydroboost in the works. "The mother of all parking brakes" on the driveline with 290,000 some odd miles. Hey, where'd those PODs go? Holy Cow! They're in the engine! |
#6 |
updated list
1) steam clean
2) kdp 3) EGT probe 4) leak check 5) front and rear seals 6) piston lift pump (thanks for that one...I would have forgotten 7) t-stat (another one I would have forgotten) 8) belts and hoses I'd love to take the time to paint the motor, but I will likely not have it. Maybe I'll just clean up the valve covers and polish them or something....I supposed I should have a little bling ![]() Thanks for the help, Russ |
#7 |
marine pistons, lost of paint and chrome and a cam, what about that about that freeze plug in the back id get that one that bolts up
__________________
96 3500 2wd, ddp 2’s, 3kgsk, #10 plate. Hybrid over s400 twins, bd full roller bearing trans, DiPricol gauges, bd torq loc and tow loc, Pac brake 4” inline, Straight 4” duals, Aux trans cooler with fan, Firestone ride rite with on board air, gauges, DSS, Centramatics, Maghytec . |
#8 |
If the motor was in front of a manual tranny, or is going to be in front of one, I would at least put a new thrust bearing in it.
Also a new rear cam plug.
__________________
92 Black W250 295K, getrag, valair 13" ceramic clutch, dana 80 3.54, HX40, DDP3 injectors, high pressure piston LP, custom IP, M&H M2 fuel pin, PS charge air cooler, 4 in exhaust w/ brake, gauges(and lots of them) Leece Neville power. 89 FUMMINS F350 4x4 crew cab, VE 12V, A518 trans, ford np205 t-case, PS cooler, hybrid HX35, low pressure piston LP http://s218.photobucket.com/albums/c...Truck%20stuff/ |
#9 |
Also, new motor mounts should be on the list, along check the frame areas in the engine compartment of the truck you wil end up using(the W250) before the engine is back in. Look for cracks, like where the power steering is mounted. I read somewhere that that area is susceptible to cracking. Weld while you have access.
If you can swing it $$$ wise, O-ring the head and upgrade the head studs, upgrade the valve springs. When doing the oil pan, plan for another oil return port for if you ever run twins one day. Look in the sticky or do a search on twins. BC847 did twins and he has pics on his install, showing the oil pan work in great detail. |
#10 |
Definitely new Throwout bearing! I agree. Might as well grab a new clutch off ebay sachs for 400 and resurface the flywheel, boring out the center for the ball bearing input shaft bearing. I did those ones as well as the lift pump. Cutting the insulation was a breeze with it out. It would've been a lot harder IN the truck.
#11 |
The only internal mod i'd do to it, is a cam from PDR. like a quickspool, there like $400 and get you up to 2mpg better from what i says, faster spool up and stuff
If you shooting to make a fun truck and don't know what you'll be doing in the future for performance but you want a good running truck..... go ahead and pull the head off and have it sent out, port/polish work and get it o-ringed. then order a marine head gasket and install the head with some studs and you'll be good to go . You'll have a more bulletproof motor ready for HIGH hp.
__________________
91.5 W250 4x4 5 speed LE Red/Grey, 270k miles, 3.54's w/ Power-Lok, 4" Exhaust, BHAF, DennyT Pin, 3200 Spring, Piston LP, Power screw maxed, HX35/12cm, DAP 5x14 Injectors, Valair 13" 550hp K/C clutch, 4" Skyjacker soft-ride lift, 315/75R16 Mickey Thompson Baja ATZ tires, 16-17 MPG 89 D150 3.9L TBI/A999 Auto, beater while ^^^ gets restored Attending LTI for Diesel Truck Technology, graduate December 2013 |
#12 |
Oh Yea Firerings And The 625+head Studs Becacuse U Never Know
#13 |
holy crap
One thing I know for sure: none of you guys have hacked into my online banking and looked at my balances!! sheesh.
You all have me spending over 1k bucks already. I like all the ideas though. I am going to go back to the 'till' tonight and see what I can come up with. Man! Russ |
#14 | |
Quote:
__________________
1985/93 Cab Crew Cummins Conversion, PODS, HX35, 3200 GSK, DTT Transmission, Cooler tubes 1998 12V all stock 1964 Dodge Sweptline Crew cab |
#15 |
WhiskeyRichard, you had to have seen all these answers coming. LOL
| Display Modes | |
