Thread Tools | Search this Thread | Display Modes |
#1 | ||
taking off the fan?
__________________
95 2500 cummins, bed bobbed 10 inches, a little speedliner here and there, FORD HIGH PINION DANA 60 FRONT AXLE, 100 plate moved forward, 3800 governor washer mod, BHAF, strait pipe, Auto meter gauges, TC lockup switch, Goerend trans, New Era 435s, 6 inch DC lift, DT track bar, Irok Radial 41/14.5/17 on cheep steels with Staun beadlocks, Atlas springs, 4.10s, Detroit in rear, Lock right in the front, KDP killed. thanks Dave! http://www.cardomain.com/ride/414017 |
#2 |
A strap wrench should keep it from moving.
__________________
J.R. U.S. Coast Guard , Electronics Technician 1st class Extra class Amateur radio operator - K5DTR 2001½ SLT 2500 2WD, auto, short bed Hi-flow banjo bolts FASS DDRP Scotty Air II Isspro EGT (pre-turbo),fuel pressure, boost, and transmission temperature (sensor in hot line) guages |
#3 |
Hold it with the other hand?
__________________
07 6.7 Electric Blue, Falcan Deck and Bumper |
#4 |
he figured it out. I was asking for a friend.
| Display Modes | |
