#1 |
Tailgate?
Does anyone have one for a 2007 Dodge or thereabouts - preferably in Khaki (the almond color)? I have a front bumper to trade for it - air dam is cracked on the left side, but a buddy has a new air dam he is giving me.
I found only one tailgate at a recycler here in Edmonton from the 8-10 called - it is white and from a dually, however they want a stupid $600 for it. So, considering paint and then boxliner spray, I'm looking well over a grand. Or, any tips on pounding out a nasty crease type dent (it is a big one) and I'll just get the boxliner spray extended. I just need to get it roughly close, then they say they can spray it with the boxliner spray, but they are unable to fill in the way it is right now. I visited a body shop and he said heat for sure as the metal is stretched??????? ![]() I am definitely no autobody tech. I can try post a pic later.Ideas are appreciated.
__________________
Member #33 - DTR MegaCab Club Join Here Another Version-AD150 Canister Mod / MegaCab Install 2007 Khaki Dodge 3500 SLT MegaCab SRW 4x4 5.9L CTD 6-speed handshaker, SBC dual disc, smoked cablights, front & rear Timbrens, Pacbrake PRXB, Bilstein 5100's, DSS, lost kitty & demufflerized, Scotty V, aluminum front bumper, remote controlled aux. lighting, Commander, Smarty POD, AD150, 2" leveling kit, Espar, P3, 80% debadged, Amsoil everything, & some bling. |
#2 |
not that i would do this myself-but you can remove someones elses tailgate with the same amount of effort as your own....
I'm honestly surprized that there aren't more of these thing stolen. My brother was telling me a while back they had a rash of thefts in Red Deer....
__________________
2006 3500 QC SLT SB AUTO, High Idle, 35 x 12.5 Dick Cepek FC2 on Incubus Nemesis 8 20 x 9, Nerf Bars, Espar Catch Me Red |
#3 |
Its CFR Weekend. $12 to get in the parking lot...
j/k ![]()
__________________
#4 |
Let's see the pic. When my truck was about 2 years old I backed up using my mirrors with the tail gate down. Sure enough garage door was open and I misjudged how much space there was to the brick pillar. Result was a brick pillar embedded in my tailgate. Using a 10 lb sledge and a piece of 2X6, with the tailgate on a piece of thick carpet I beat the tailgate close to shape. I then used a slide hammer to get it closer, a small amount of filler and a stainless tailgate cap finished it off. I had to cut a little of the spray in box liner away but most of it came back OK.
__________________
2001 2500 quad 4X4 5 spd Stock except gauges |
#5 |
Kerry, talk to Dave in Cgy, he is amazing with body work and paint. (dieseldave)
__________________
03 2500, Almost Stock 10.84 @ 128 MPH April TOM Winner |
#6 |
You can find decent tail gates at the wreckers or phone your local auto parts store. They aren't that badly priced. You can fix dents, buts abit of work. Heat the metal until its cherry red and use a cold wet cloth. That will shrink metal, do it to much and you tear the sheetmetal. Most body shops just replace that part of the truck. Its kinda like hoods. Its just easier to replace the part. They a so make RV tail gates cheap and look decent
As for the driveby pick a part stuff, ![]() ![]()
__________________
02 sport QC, SB, 3/4 4X4 DDP stg 3 sticks, back to single little tiny turbo GT3782R -Kore Recon and a few DSS parts stuff on the front. -Half worn out DTT Race tranny and the cruise control still works. -2500 watts stereo, four amps and twelve speakers cranked to the limit |
#7 | |
Quote:
I won't do the five finger tailgate thing although I wish it was that easy. |
#8 | |
Quote:
Agreed, Dave is awesome. ![]()
__________________
Greg's Truck 2001 Dodge Ram 2500 QCLB 4WD, Automatic, 3" Carli Leveling Coils & Control Arms w/ 18" XD Addicts and 35" Dunlop Rover M/Ts, Quad Adrenaline/Smarty stack, AFE Stage II, CFM+ Intake Horn, ARP 12mm studs, 5" flex into 6" single miter stack |
#9 |
Here's some really poor pics:
#10 |
I would hate to say this but its fixable, but its not worth the effort. You'll have a bunch of mud in the gate, to make it straight again. Buy a new gate. Look around. In C-town, you could phone cross canada or LMC buy. Nothing in the bone yards?
![]() http://www.lmctruck.com/icatalog/de/full.aspx?Page=20 |
#11 |
Shipping from LMC would double the price unless you had it shipped to Monatana or something.
__________________
'96 CC LB slt,auto,3:54's,100hp Maxsticks,3k gsk, afc modded,16*,62/70/13 Turbo,4"exhaust,bhaf, DSS, triple lock TC, rebuilt auto & diff,MBRP 4",3 pod pillar egt, boost, oil pres,ride rites frt & back w/ onboard air, lubetech through out, 437K km's 333hp 760 ft/lbs |
#12 |
I just phoned AMP in Edmonton, they want $392.86 for a NEW tailgate for single rear wheel 2007 . Phone number is 780-455-3171
Apparently the dual RW has a cut out for brake light, they don't stock that one. I use AMP for all my sheet metal parts and lights.They are just off the Yellowhead around 127 st. |
#13 |
Thanks. I'll give them a shout.
#14 | |
Quote:
__________________
2001 2500 4x4 Edge Juice(wire tapped) HTT Super Stock 62, F1 Mach 4's, BD Intercooler, South Bend DD3250, FASS, 3rd Gen track bar, PSC Steering box stabilizer. 540hp/950tq@45psi |
#15 |
Hmmm....Festus....what did you hit with that tailgate.. ![]()
__________________
1995 Dodge,250K miles, regular cab dually,4X4,5 speed,4:10 gears,Wastegate blocked,15 degree timing,Polyurethane control arm bushings,BHAF,KDP Tabbed,Pyro & Boost,DSS,2003 trackbar upgrade,Steerring bushing,#0 plate,3K springs,215 injectors,Laser cut DV,Con OFE,full B100. Mar 2008, Dyno: 353HP/735 Ft Lbs June 2008 Dyno:344HP/835 Ft Lbs 1978 Mercedes 450SL 1956 Chev 4 door Sedan 1977 T/A 400,4-speed 1963 Ford Falcon,2 door |
| Thread Tools | |
| Display Modes | |
