Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-26-2008, 04:54 AM   #1
lumpy_63
lumpy_63's Avatar
Surging / dead pedal
About 6-8 months ago I had a FASS HPFP installed (stock LP was dying). Ever since, the rpm surges slightly when truck is first started up (never happened prior); it goes away in minutes. Truck always starts right up and fuel pressure is good (14-16 psi); mileage is 17-18 mpg; no smoke at startup most times. Never thought much about the rpm surging but recently I had dead pedal 3 or 4 times (push on pedal, no go; let off and push again and it goes). No codes (checked by scangauge, key on/off/etc test, also had a diesel shop check with their scanner). Is the surging indicating a problem that I need to address? Thanks for any help.
__________________
Red 2002 Ram 2500 4x4, Cummins, 47RE auto, 78K miles, longbed standard cab, 285/75/16 tires, Magnaflow muffler, Dipricol fuel pressure gauge plumbed to bottom of fuel filter housing with needle valve, FASS HPFP lift pump - 15-16 psi at idle, 12-13 psi wot. Isspro EV2 EGT gauge. Q'zilla Max Mileage module (someday to be an XZT...) VP44 changed @ 91K due to persistent 216 code
lumpy_63 is offline   Reply With Quote
Old 06-26-2008, 09:16 AM   #2
haloman
haloman's Avatar
Some VPs die without giving codes.
__________________
Daniel
01.5 2500 CTD 2wd 6spd QC/SB Green SLT
haloman is offline   Reply With Quote
Old 06-26-2008, 09:44 AM   #3
lumpy_63
lumpy_63's Avatar
That is my biggest concern. I took it to a diesel shop that replaces a couple of vp44s a week. They scanned for codes (said you couldn't always get Cummins codes through the OBDII port) but found none. They said since the truck is still getting good mileage, without hard starts / smoking, I am probably OK to continue driving it for now, and thought it might be the APPS (though they weren't sure). I am not so sure about that...
Old 06-26-2008, 09:55 AM   #4
haloman
haloman's Avatar
I am kind of in the same boat as you. The truck was hard to start hot once back last winter and has dead pedaled twice in the last month but its hard to say since the tank was low at that time also. My truck has surged slightly when really cold in the winter but it has done it the past 30,000 miles I have drove the truck. I think I will run it until it stops going/running really badly.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
