Thread Tools | Search this Thread | Display Modes |
#1 | ||
Straight Pipe
__________________
1997 Dodge Ram extended cab Dually Cummins 5.9 w/4.10 Gears. BHAF, silincer ring removed, boost, egt & tranny temp auto meter gauges and MAG dd tranny pan & Bully Dog 4" turbo back exhaust. Drag race a 2004 Toyota Celica. Rear wheel drive with 1400hp to the wheels. 7.21 @ 192mph Yep, its a 4 cylinder. Amazing what 53lbs of boost can do. |
#2 |
Re:Straight Pipe
almost everybody has it helps some but most do it for the sound ;D. you can probably by the pipe from a local muffler shop and save some $
__________________
SIX IN A ROW BUILT TO TOW,CUZ WELL WE ALL KNOW , HAVING A V-8 AIN'T THAT GREAT Dodge trucks that havent made life expectancy 96 3500,-175k 98.5 3500 -164k ,98.5 3500-275k, 01 3500-140k, 03 3500 -155k, 07 3500 68k 06,3500-155k, 04 f350 4x4 drw getting a real diesel in it.. |
#3 |
Re:Straight Pipe
I'd gut your cat first.<br>They have more restriction than the muffler.<br><br>If worried about legality, just take it off, hollow it out, put it back on.<br>Then proceed with a mufflerectomy.<br><br>Not much in the mpg or HP, but helps with EGT's while towing or racing.<br><br>And sounds great as well.<br><br><br>phox
__________________
2002.5 Dodge Ram 2500 4X4 SOLD 2009 Jeep Wrangler Unlimited X 4x4. Detonator Yellow in color Bone stock for now, at least for a couple months 2008 Harley Davidson FLHR Road King. Black Pearl in color 12 inch apes, stainless cables, Vance & Hines pipes, garage door opener, combo speedo/tach |
#4 |
Re:Straight Pipe
Mufflerectomy
To funny!!! Your right. I never thought about gutting the cat. I will probably do both. I might as well if Im gonna go under there messing with things ;D<br><br>Thanks!!!<br>Luis
#5 |
Re:Straight Pipe
Paradise Racing:<br><br>You can order a "catalytic converter test pipe"<br>from Dodge for your truck. This pipe was used<br>by the dealerships to check and see whether<br>or not a stock converter was bad or not.<br>It fits directly in place of the catalytic converter.<br>I used one on my truck awhile back. As I recall,<br>it cost around $49.00. The Dodge part number<br>is: #52019170AB. <br><br>--------<br>John_P
__________________
Red Ram Rocket Scheid Diesel Tuned Pump, Scheid Twin Turbos, Scheid Arias Pistons, Scheid Cam and Ported Head, FASS, Scheid Water Inj.,Fluiddamper,ATS Stage V Auto Transmission in a 96' Dodge CTD Ext.Cab 4X4 (Best E.T.11.42-Coastal Plains Dragway, J'Ville, NC. Best MPH: 11.42@119.4 MPH (Coastal Plains Dragway,J'Ville,NC 871/1680 TQ. "Western NC Dyno Day 09/18/10 891/1585 TQ. "Fall Brawl", Oct.2007, Pa. 889/1343 TQ. "Western NC Dyno Day, 06/21/08 ------------- 2006 Flame Red 2500 Quad Cab, SLT, SRW, 4X4, Thunder Road Package, DiPricol "Optix" Gauges, TST PM 3 CR w/R-49, Smarty, Schwitzer 62/12, ATS TripleLok Stage V Auto. 460 H.P./845 TQ. 580 H.P./1030 TQ.(Best #'s) Done with Smarty Beta 13.1@105 MPH (CPD, J'Ville, N.C.) Vice-President of NCDTR Chapter #18 DTR "TOM" Winner June 2010 |
#6 |
Re:Straight Pipe
Just go ahead and kill the cat and drop that muff. If you have access to a mig welder you can do it yourself, its not that hard and you will definately like the sound ;D. If not take it to your local muffler shop they shouldnt charge you much. Oh and while your at it go ahead pull your silencer ring out ... it'll whistle more that way
all you need is a set of snap ring pliers or a couple screw drivers.<br> Good luck<br> Wheels
#7 |
Re:Straight Pipe
My local exhaust shop did it for $65. Sounds great.<br>Scooter
__________________
2002 DRW, 6 speed, Quad cab, Comp,Staight pipe,south bend |
#8 |
Re:Straight Pipe
these trucks have cats?? I thought it was a resonator.
__________________
'99 Quadcab,4x4,auto,3.54 limited slip,shortbed, Red/silver,Alpine c/d,4 Infinity speakers,6x9 kappas front & amp; 5 1/2 kappas rear,4" stainless exhaust,285/75x16 Bridgestone Revo's on Mickey Thompson wheels. Suspension is next. Support our Troops. |
#9 |
Re:Straight Pipe
Hi is that test pipe bolt on, clamp on or weld on?<br><br>Thanks!!!<br>Luis
#10 |
Re:Straight Pipe
It is a resonator.<br>Scooter
#11 |
Top's Younger Twin
Re:Straight Pipe
I think the pre 24 valve 2nd gen trucks had cats...24 valve 2nd gens had a resonator.
__________________
#12 |
Re:Straight Pipe
[quote author=CTD 359 link=board=7;threadid=11851;start=0#112522 date=1046991192]<br>I think the pre 24 valve 2nd gen trucks had cats...24 valve 2nd gens had a resonator.<br>[/quote]<br><br>Ditto.<br><br>12valve=cat<br>24valve=reson ator.<br><br>The early 24v's might have still had a Cat until DC did away with them and went with the resonator.<br><br>phox
#13 |
Re:Straight Pipe
10-4<br>Scooter
#14 |
Re:Straight Pipe
Luis:<br><br>The test pipe slips in exactly where the cat is and you<br>then just use the clamps to hold it. The one I had fit<br>right in with no problem.<br><br>-------<br>John_P
#15 |
Re:Straight Pipe
Thanks John_P, I will order it tomorrow.<br><br>Luis
| Display Modes | |
