Thread Tools | Search this Thread | Display Modes |
#1 | ||
steering gear box replacement?
__________________
2001 Dodge 2500 Diesel 4x4 Quad Cab Auto 265-75r16 Nitto Dura Grappler 4" Turbo back MBRP muffler Flex-a-lite fans. |
#2 |
If I had to do it again, I probably would get an X-Treme duty box from here:
http://www.pscpowersteer.com/Perform...nggearsPSC.cfm They have been getting good reviews at pavementsucks.com. I guess the guy that owned AGR Steering started the company after he sold AGR. That's why AGR is crap now. |
#3 |
I just replaced my steering box with a rebuild from a local company. The box cost $240.00 CDN, exchange (I got a better deal.)
The rebuilder tightened up the box an made the ratio a little better. I am very happy. The repacement took me about an hour...two lines, three mounting bolts, one bolt on the steering shaft, and the PITMAN ARM. You will need to get a Pitman puller (rent or borrow). I can get the info on the shop if anyone wants it. george
__________________
george '94 3500. AUTO 354 rear' #4 plate, 3000 GSK, 370's' BHAF' and 4" Drain pipe 470,000KM '08 3500 DRW Laramie QC LB 4x4 auto Silver WBCCI # 3155 |
#4 |
Don't bother messing with the adjuster bolt, it won't stop it from leaking but it can screw up your steering. You might want to try some of the PS stop leak thats at most parts stores, I think the only thing that seals the adjuster bolt is an o-ring and that stuff might swell it up.
#5 |
O K here's the results.. I was able to tighten the bolt a smidge and that did it. Just to be on the safe side I topped of with Lucas Stop leak and I haven't had a drop since... So hopefully that will last a while.
| Display Modes | |
