Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-02-2009, 11:23 PM
jimbo486's Avatar
jimbo486 jimbo486 is offline
starwheel adjust
i turned my starwheel this evening. i marked the wheel itself on the front side to reference how many turns i've made. i used my fingers to turn it. the flathead screw driver just became a PITA to use. i thought the wheel was really that hard to turn, but it turned easily with my fingers. anyhow i only made a half turn for now cuz i just wanted to see when it becomes a noticeable mod. it seemed to feel a little more responsive on the low end and i can understand why. but one thing i was curious about is, can you lose top end (high rpm) power when the starwheel is turned in/spring tension is lower? i can recall, after shifting into 3rd and accelerating, seeing my tach up around 2900rpm. i've never seen it go that high but don't think i've ever let it get that high when shifting before now.
i was also thinking about removing the nylon washer under the rubber diaphragm to see if that's a noticeable difference as well. i know some guys shave it and some remove it altogether. any opinions / advice / thoughts are welcome to be discussed.
__________________
"my name is jim, but most people call me.... jim"
- blazing saddles -
- '90 D350 LE Cab & Chassis -
159" WB - Custom 9' bed - Fuel pin turned - 1/2 Turn On Starwheel - 4x.014's - Piston LP - Banks Intercooler - 4" Turbo Back, Sans Muffler - 500K+ Miles (ODO Stuck @ 258K) - NV5600 - D70 3.54 LSD - Autometer Tach - VDO Boost - Autometer UltraLite II Pyro
Wish List: GDS 60mm, 3" Cooler Tubes, M3 Fuel Pin
Old 11-03-2009, 07:43 AM
squarenose's Avatar
squarenose squarenose is offline
Heard of people shaveing the washer too. Also removeing the whole starwheel as well
__________________
'92 D-350 LE dually Auto, single cab, flat bed, straight exhaust, K&N filter, LED gauge cluster refresh, White faced gauges, turned fuel pin, Starwheel bottomed out, 3 on the smoke.
Old 11-03-2009, 08:58 AM
CaptainChrysler's Avatar
CaptainChrysler CaptainChrysler is offline
Depending on your pin, yes you can go too far. If it gets so low that it "over centers", meaning the cut in the pin starts to ramp back out the the O.D. of the pin, it will defuel. It can happen if it is too tight as well, and it the spring bottoms out before the deepest part of the power pin gets down the the smaller control pin.
Put some grease on it and test drive to see where it is riding.
__________________
Curt
Driver:
'93 W350 CC SRW Getrag:
3200, 370's, HX40, BHAF,HP Piston Pump, Big Lines, Pull Cable, Valet, 5" Straight Pipe, AM Tach, C2 Boost and Pyro Borgeson, 240K
To do: PS-IC
Puller:
'89 W350 RC SRW Getrag/NV273:
6x.016's, 4200, H1C/ HT3B Twins, A1000, SBC DD, Water-2-Air IC
Hydro asst Steering, Big Weight Box
Old 11-03-2009, 02:23 PM
Benjamin b2's Avatar
Benjamin b2 Benjamin b2 is offline
grind it deeper and pull the washer out
__________________
Pickup #1 1991 w250, 5spd, reg cab, now intercooled 3rd gen style, afc lever MIA, lucas POD's, timed to head, piston pump, hx-35/12, 3" tubes,BHAF 2790, jacobs brake, luk pro gold cluch, 4" exhaust from dp, summit regulator @ 16psi, pyrometer, flatbed, 304,000 miles
Pickup #2 1993 w250, IC, auto, reg cab, billet conveter, steel planitaries, bone stock motor, 158,000 miles flatbed
Pickup #3 1993 Nissan hardbody, 2.4l 4cyd, 5spd, 325/60/15 bfg's
"feelin lucky punk" clint eastwood
Old 11-03-2009, 03:04 PM
jimbo486's Avatar
i can see where the pin has been riding since i turned it to the deep portion of it. it's got plenty of brown crap on it from something which really worries me, but i've been told to not worry about it. i probably have about an 1/8" or so of travel i could use up. i should've taken a picture or dimension for a reference to see just how much of a difference a 1/2 turn of the starwheel would make.
__________________
- blazing saddles -
Old 11-03-2009, 06:38 PM
wannadiesel wannadiesel is offline
How can I best help you today?
The best substitute I've seen posted for the nylon washer is an o-ring. Thick enough to keep the pin from over centering, but thin enough to get you full travel.
If you do your own custom grind you can make it so you don't need any washer.
__________________
Dave
wannadiesel@dieseltruckresource.com
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air!
"Butterscotch" - '82 Mercedes 300TD
KDP body count: 72
Old 11-03-2009, 06:43 PM
jimbo486's Avatar
are you talking the OD of the o-ring being small enough to pass through the opening but not too small that it would cause the pin to "fall" out of center? is that what captain chrysler is getting at? i think it was mr. jim lane who used 2 o-rings. i've got an assorted o-ring set in the garage i could play around with. i really doubt i'd ever grind on my stock pin though cuz i don't have a spare to replace it with if i screw up.
__________________
- blazing saddles -
Old 11-03-2009, 06:46 PM
No, an o-ring that fits the pin tightly.
__________________
Dave
KDP body count: 72
Old 11-03-2009, 06:49 PM
jimbo486's Avatar
ahhh ok. i understand that. the washer is just a depth limiter right?
__________________
- blazing saddles -
Old 11-03-2009, 06:50 PM
Yep.
__________________
Dave
KDP body count: 72
Old 11-03-2009, 06:58 PM
jimbo486's Avatar
so would my thinking be logical if i were to take a dimension from the top of the wear mark to the larger shaft of the pin and use that dimension as washer or o-ring thickness to get the right amount of depth? i know i've read that the pin can't be pushed far enough down to do any damage anyhow, but some how i think it's possible for it to be pushed too far if you have really low spring tension (or no spring at all) or if your boost pressure is really pushing down on the diaphragm above it.
__________________
- blazing saddles -
Old 11-03-2009, 07:01 PM
Exactly!
__________________
Dave
KDP body count: 72
Old 11-03-2009, 07:06 PM
jimbo486's Avatar
sweet! so the starwheel adjustment does have somewhat of an effect on depth also. but as long as the o-ring or washer is present, there should be no chance of damage occurring. thanks again dave!
__________________
- blazing saddles -
Old 11-03-2009, 07:10 PM
You can set the star wheel too high, wind up with the spring stacked solid and not get full travel. But that won't damage anything.
__________________
Dave
KDP body count: 72
Old 11-08-2009, 03:52 PM
adam greene adam greene is offline
how do you adjust your starwheel
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
