starting problems
Old Dec 16, 2002 | 09:37 PM
doodah's Avatar
starting problems
truck will start fine one time , and will not start at all the next . any ideas ?
Old Dec 16, 2002 | 10:23 PM
phox_mulder's Avatar
Re:starting problems
Memory isn't what it used to be, diesel fumes probably aren't helping,<br>What year truck do you have?<br><br>phox
Old Dec 17, 2002 | 09:09 AM
doodah's Avatar
its a 97 and right now this morning as i speak i cant get it to start at all. it acts like it aint gettin fuel.
Old Dec 17, 2002 | 09:11 AM
Rammin On's Avatar
Check the fuel shutdown soleniod ...
Old Dec 17, 2002 | 09:15 AM
berner's Avatar
Check your shutdown solenoid to make sure it's opening. It opens when you engage the starter. If it's not opening you can lift up on the plunger rod with the key on and it should stay up until you shut the truck down.
Old Dec 17, 2002 | 09:19 AM
doodah's Avatar
where exactly is this located at? there is a like a bulb valve on the drivers side of the motor and this is soft isnt it supposed to be hard?
Old Dec 17, 2002 | 09:24 AM
Rammin On's Avatar
It's round and has a rod attached covered with a rubber boot .... it's bolted to your AFC ...... pull up on it and see if it starts .... relay could be bad or the soleniod shot ... or sticking .... <br><br>
Old Dec 17, 2002 | 09:36 AM
doodah's Avatar
afc?
Old Dec 17, 2002 | 09:40 AM
Rammin On's Avatar
Aneriod Fuel Control on the injection pump .... just aft of where all the fuel lines are ... looks like a hump on the back of the pump ...
Old Dec 17, 2002 | 09:47 AM
Rammin On's Avatar
Here's a pic
Old Dec 17, 2002 | 09:48 AM
Rammin On's Avatar
And another
Old Dec 17, 2002 | 09:52 AM
doodah's Avatar
sorry, i just cant seem to see what your refering to is it on the top side of pump towards the motor itself or what. is it something i need a pliers or screwdriver to lift or what? looked all over for this. still kindof new to this motor.
Old Dec 17, 2002 | 10:00 AM
Rammin On's Avatar
the solenoid is located on the injection pump towards the firewall on the drivers side. There is a plunger rod that is attached to the pump lever. Pull up on the lever.
Old Dec 17, 2002 | 10:07 AM
berner's Avatar
Here's a link to a diagram which shows where it is. Engine Diagram
Old Dec 17, 2002 | 10:19 AM
doodah's Avatar
i think it is mybe a cracked fuel line. if i crack open the #1 injector and turn it over, i can get it to start but i will have to get a buddy over so i can close the line after i get it started.. prognosis-- air in the fuel line??? ???
