Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 11-08-2008, 03:27 PM   #1
HARDTIMES
starter going out?
went to fire it up today and when i turned the key it made a clunk sound down by the starter so i kept turning the key about three times and every time i turned the key it would just make one clunk sound then fired up so i tried it a few more times and it was fine....i was just about to buy a fass
__________________
92 w250 5spd scheid 5x18's 160 p-pump studs sps66 FASS sbc dd3600 5" single stack 584rwhp
HARDTIMES is offline   Reply With Quote
Old 11-08-2008, 03:33 PM   #2
jjdiesel1990
jjdiesel1990's Avatar
Whenever it makes the clunk sound have someone hit it with a hammer while you crank it.
jjdiesel1990 is offline   Reply With Quote
Old 11-08-2008, 05:15 PM   #3
93flatbed
93flatbed's Avatar
You can have the starter rebuilt. I would not suggest goin to Dodge for it, Just went though the same problem, Dodge is 600$ for me(work a dealer) and for a guy on the street is 880$ for a new starter. I went to a local shop here and they beefed it up and rebuilt it for 86$ out the door. But also you could pull it apart and try cleaning the contacts on your own. But that is just goin to give you some more time before the time comes to get it replaced/ rebuilt.
Justin
__________________
1993 W250, single cab, hunting for Jeremy.
1981 crew cab powered by 93 w250 drivetrain
Special thanks to Rob @ highway chopper for machine and head work.
93flatbed is online now   Reply With Quote
Old 11-08-2008, 06:19 PM   #4
wannadiesel
It's the contacts. You can replace them yourself, there's a thread about it in the sticky.
__________________
Faith
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air!
Dead KDP's = 72
wannadiesel@dieseltruckresource.com
wannadiesel is offline   Reply With Quote
Old 11-08-2008, 06:21 PM   #5
Kenny D
Kenny D's Avatar
yep i bouhgt new contact for my 2nd gen for about 10 bucks its pretty easy to do. Lasted for years till i sold the truck
__________________
2005 600HO 4x4 DRW Auto
6" skyjacker 3"body lift. custom rear diff guard. Welded on ROADARMOR bumper. 6"stacks built not bought straight piped. mp-8, AFE int, bypass oil filter. Full built DTT. , 10" SUB CUSTOM BOX. 65 gal stainless steel fuel tanks under bed(built not bought) + the stocker. 3 air horns, 4 gal air tank with hose outlet. AND MORE and yes i tow all the time
NRA LIFE MEMBER
GOD BLESS AMERICA
Kenny D is offline   Reply With Quote
Old 11-08-2008, 07:07 PM   #6
HARDTIMES
cool thanks guys ill check out that sticky
Old 11-09-2008, 12:23 AM   #7
Machinos
The starter on the slant six in my '78 started doing that years ago and I haven't ever fixed it, since it always started eventually...although eventually it probably wouldn't have.
$880 for a starter is ridiculous. NAPA has rebuilt ones for $219 and you can probably get them done cheaper at a local place.
__________________
1990 Ram "350" C&C, extended frame
Machinos is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
