Thread Tools | Search this Thread | Display Modes |
#1 | ||
Springs
#2 |
i have a 90 d250 and i defidently don't have that many
#3 |
I have 8 PLUS overloads on the back. If you are looking to get a better ride, some members have flipped 1 or 2 to get softer rides. Or th more expensive route, air bags.
That is all I know. Jon
__________________
1992 W250 G360~ Wife calls it Satans' Lavatory |
#4 | |
Quote:
__________________
BLACK 1992 Dodge Cummins Turbo Diesel-4x4-Standard Cab-9 Speed Rag+Gear Vendors-4:10 d70 limited slip w/ 11 leaf springs!!-167,000...and slowly counting. Mods to date: Rebuilt HTT Stage IV H1C/E 14cm w/g-366 spring-3/4 turn on fuel pin-star wheel bottomed-BHAF Outerwears(filter minder)-AD165 w/ sump-Isspro Pyrometer/Boost/Trans/Fuel 4" Exhaust-Trans Coolers-Buckstop Bumpers 1-24-09: 158hp 408tq (Dynojet) |
#5 |
Since you are a 2wd you can get away with pulling some leafs out. Pulling them on a 4wd with the tall lift blocks adds some axle wrap.
__________________
93 W250 Clubcab, LE, getrag 5spd, 3.55s, straight pipe, Isspro guages,BHAF, KDP dead, fuel screw 1 turn past collar, Old Smokey fuel pin, timing 1/8", 18.5cm, 30lbs boost, 220K miles. |
#6 |
an old timer told me years ago to pour used oil on the springs to help with the friction and wear,thats before the tree hugger days
,so...my truck has 7 each side,rides pretty good empty,and really poor loaded.i have air bags too,adding air help the ride,but not much.yea i dont understand it either.you would think that load it would ride better,oh well.
__________________
92 350 dually 2wd,"ol stinky",airbags,pump tweeked,getrag,swiss'd airbox,rad support,lower grill,4.10/215's,straight 3" exh,runs 11.40's 1/4 mi,just kiddin' ...smile,serious sucks 03 d-max,edge,juice,4"exh,air intake,maybe more? 89 k2500 86 gmc c70 dumpy 69 newport survior 69 dart gts 383 4spd 5-70 road runners heavy equipment,loaders,bobcats,ect bunch of mopar stuff,and looking for more{sickness} |
#7 | |
Quote:
#8 | |
Quote:
daryl
__________________
----------------------------------- daryl & wendy HIS- 93 d350 excab,getrag,3.54.bhaf,htt stg iv,banks intercooler,16cm,bosch 185's,,fuel screw 2 turns,pump 1/8 advanced,pacbrake HERS- 93 d250 excab,518,3.54. stock until she ain't lookin |
#9 |
Muted User
i think someone welded mine solid at the factory, LOL, cause mine rides like crap empty, loaded it rides great, put a bobcat on a bumper hitch trailer and a load of tools in the bed and it rides like a cadillac.
__________________
UNITED STATES MILITARY: ESTABLISHING PEACE THROUGH SUPERIOR FIREPOWER SINCE 1776 THE FEW, THE PROUD, AND THE VE POWERED 1990 D250, RC LB, 2WD, 5.9 TOWER OF POWER, 727, SEVERAL TURNS OF THE FUEL AND SMOKE SCREW, NO AIR BOX, STAR WHEEL AT THE BOTTOM, NO THROTTLE STOP, NO AFC SPRING, PIN TO THE FRONT, STRAIGHT PIPED, COBALT BLUE VALVE COVERS AND LETTERING, 16X8 WELD SCORPIO V'S WRAPPED IN 265/75/16 FIRESTONE A/T'S, MORE POWER WILL COME SHORTLY....... |
#10 |
Thats how mine is...how they should be. It rides rough empty because our trucks are so light on the rear, taht theres nothing to hold them down when ya hit big bumps. Get a little weight back there, and youre just sailing along.
__________________
Randy The New Rig: '99 QCSB 2500 4wd auto. Smarty, 35/12.50/17 tires, otherwise stock... Traded: 1991 D250, 7.3 intercooler, DennyT stg 2 pin, POD's, HX35 (14cm), SB3250 DD clutch, custom intake and cooler tubes, SW Fab bumpers, Headache rack, homegrown grille inserts, piston LP |
#11 |
A guy I know about bolted about 500 pounds of tractor weights underneath the bed. Everyone says it rides real nice now. Plus he has all the bed space too.
Jon |
#12 |
My 92 W250 has 8 leafson each side. I went acrosse the scale at the junkyard with 5720lbs in the box, I love my Dodge. My 48 flatfender power wagon has 14 leafs with another 6 in the overload stack rides great hahaha!
__________________
2005 2500 4x4 6spd 4dr long box Lone Star bumpers, TS MPD monitor, muffler delete, otherwise stock. Sold-1992 w250 5spd, Pods, bhaf, custom ground fuel pin, starwheel full down,fuel screw in 3 1/2 turns, Ip maxed toward head PS 62/12, 4 1/2 inch exhaust, 3200 spring, Autometer pyro,boost,tach, pull cable, sbc con-fe, snow stage 2 water/meth 376/851 #2 only 1948 b1 Power Wagon 1997 H-D Fatboy custom Guns kill people like spoons made Rosie O'Donnel fat! |
#13 |
When I do find some Stick overload springs will I need to make any changes at all or is it just a direct bolt on? Reason I'm asking is because I do not want to change out the existing spring pack that I have now.
Thanks WW |
#14 |
Thats no joke, I weighed my truck a while back. Was around 6500lbs and right around 2K was supported by the rear axle. I didn't write down the exact numbers.
#15 |
i just brouth home a truck that has 10 on either side in the back and none are overloads, all of them are in play all of the time! guy said he bought them at a salvage yard of a 1st gen dually... has the reciept for the rearch and install. you want to know how it rides? when my friend and i got back he was in the hospital the next day... it had broken loose some kidney stones that were forming in his kindneys! i told him he owes me since they were still fairly small and weren't allowed to get bigger, lol. 2300+ miles home... it was a LOOONGGG ride
__________________
1991 W350 SRW, 36" cab stretch, NV4500. 4.10 lsd. 61k. 2nd gen. seats, gauges. pump tweaks. PODs. TIMING. 12cmWG. HTT Stage III. Water Methonol. BHAF. #2 311.5hp 723.8tq WM 372.5hp 837.1tq Past trucks: 1992 D250 CC Auto, 1992 W250 CC 5spd, 1991 W250 Auto, 1993 W250 NV4500, 1993 W250 auto, 1991.5 W250 auto, 1992 D350 auto dually, 1992 D250 CC Auto, 1985 D350 4-door auto dually (gasser)... |
| Display Modes | |
