Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 08-29-2011, 06:09 PM   #1
MYBIGREDTRUCK
Something very strange just happened......
I need a little help. I just drove my dodge to my shop to hook to the boat; when I turned it off, it didn't want to stop. I mean it didn't run like normal, but it sounded almost like it was trying to run on 1 cylinder or something. I couldn't choke it down by putting it in gear, but if I turned the key back on it just started to run again normally. It did this several times, so I pulled it back out into the yard. It shut off normally that time, so I cranked it probably 20 times in a row, with no problems. What's up with this???? Any info you guys can give is very much appreciated.
I did a search on starting problems and there was a lot mentioned about the starter contacts; I have been having an intermittent problem with the truck not turning over every so often, but the second try it works fine. Could the starter contacts have stuck?
__________________
1999 RAM 2500 4X4, (85,000 MILES) WITH 5 SPEED; ADDED A WESTACH FUEL PRESSURE GAGE, FASS FUEL SYSTEM AND AN EDGE EASY.
MYBIGREDTRUCK is offline   Reply With Quote
Old 08-30-2011, 07:49 AM   #2
jstone44720
Probably stuck starter contacts. Check that you didn't blister the paint on the solenoids for starter and fuel shutoff. They may be toasted inside and fail soon.
__________________
1994 2500 CTD 2WD SCLB, NV4500 - 251K - SBCDynomax -09 , Autometer Pyro,Boost, and FP Gauges, TST #5 Plate and Elbow, 3k GSK, 16° Timing
Pop's Project : 2008 QCSB 4WD - G56 - 48k - Deleted, Mini Maxx, 5" TBE, Pusher Intake, SB DD
jstone44720 is offline   Reply With Quote
Old 08-30-2011, 02:30 PM   #3
MYBIGREDTRUCK
Thanks for the info. I drove the truck to a fuel injection shop and talked to the owner there. He said he had not heard of one doing what mine dd, but if it were him he would start with the starter relay. It wasn't expensive and easy to change, so I replaced it. If that doesn't do it, I'll do the starter contacts next.
Old 08-30-2011, 05:13 PM   #4
MYBIGREDTRUCK
Okay, the starter relay did not solve the "turn the key but no joy" problem. I guess my next project will be starter contacts.
Old 08-31-2011, 04:14 PM   #5
MYBIGREDTRUCK
Okay, I put in new starter contacts; so far so good.
Old 08-31-2011, 07:33 PM   #6
Lil Dog
Lil Dog's Avatar
Did they look worn and grooved?
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55.
Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III inj, BD Super B Special Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside.
Dyno 09-2009 405 RWHP / 1050 Ft-lbs
'08 2500 4x4 MegaCab Laramie, 6.7L BlackTEC, 68RFE, 3.73 LSD, Smarty S67-ME, MDKRam air.
Lil Dog is offline   Reply With Quote
Old 09-04-2011, 07:53 AM   #7
MYBIGREDTRUCK
Smile
One of them looked pretty good, but the other was badly worn, (down to the thickness of a sheet of paper). Been driving it for several days now with no more problems.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
