#31 |
Yep, hot topic. However, the proof is in the pudding. Do some research and you will find that there are plenty of excellent UOA's to look at from people running CTD pickups that are using CJ oils (Early Cam wear would be easily caught with a UOA.) I have used AME Amsoil 15-40, and am now trying Schaeffers 5W/40 which is CJ. I have some Delo 15-40, rated CJ, that I will not hesitate to use. I think for the money the JD plus 50 15-40 is probably a great oil and as everyone probably knows it CI+4. Member Roperteacher has used it with good UOA's. They will continue to make it for years to come and any John Deere dealership carries it, only around 13 bucks a gallon. I have not heard or read of anyone wearing a cam out or any other lubrication problems from CJ rated oils. IIRC Terry Dyson has no bad things to say about the CJ formula. Google him if you want, his business specializes in reading UOA's - I think he is a tribologist I am not sure. Anyway IMO, any correctly rated oil changed regularly will not give any problems. In fact, I would be interested to see if someone had an engine grenade because of poor lubrication from any properly rated oil that is changed as required. I have never heard of it, bit would like to read about it if anyone knows of a case.(Oh,I would add ZDDP with installation of a new cam even with a good CI+4) Cheers
__________________
06 3500 SLT,DRW G-56, Q.Cab, Commander, Quad Race, Smarty TNT-R, HTT 62/65/13SS, GDP airhorn, Flux 1's. Formula 1 V.springs, ATS Exh. manifold, ARP Head Studs, Stage 2 Floor it CP3, GDP Walbro w/2mic F.Filter, AEM Workhorse, SouthBend 3250 dd clutch, Opie Bypass, Fluid Dampner, metal rollup tonneau cover, Headache Rack, B&W Turnover Ball, Grover Triple Air Horns, Ranchhand Bumpers, Fr. & Rr., ROCKSTARS, other goodies. |
#32 |
Amsoil has stated they have no current plans to discontinue their AME...which is not surprising, as it's one of their biggest sellers.
__________________
2006 Six Speed 3500 4x4 Laramie "J", Debadged, AFE Stage 2 SI, Hushpower 4", Excelaguard, ATS Arc Flow, Amsoil, Rokktech Sensor, Undercover Tonneau, EMS Offroad hubs, 2008 steering upgrade, SS steering stabilizer, South Bend OFE, Autometer pyro, boost, fuel on the A, Fluidampr. |
#33 |
Yep, a great oil too. I had some high iron levels with it, but I am not blaming it on the oil, because truck was relatively new, and I flogged it quite often cause of recent mods I had done.
#34 |
I have gone back to AME. For good. It's what I'm sticking with from now on, unless I'm in an area where I can't plug in for extended periods...then I'll run the Amsoil 5W40.
AME is very good in cold weather, though. |
#35 |
D - What was the clincher, reasons you decided to stick with AME foe good, besides the fact that they plan to sell it for as long as people buy it in quantity?
#36 |
There is an old thread on here I'm going to try and find. Don M did some independent testing on the zddp levels between many of the CJ's and the CI's still out there and found the zddp levels in the CJ's to be to drastically lower,as much as 75%. Reason for the testing was he was seeing premature wear on the cam lobes on trucks that had been running CJ. Like mentioned earlier, our flat tappet design needs the higher zddp levels.From the way I understand it, it is one of the main ingredients that helps the oil adhere to moving parts so that there is an oil film to prevent a "dry start-up".To each their own, JD 50+ CI is only $1-$2 per gallon more than the CJ's at your local auto parts store. Thats cheap insurance in my book.
Hey Nelrod, get up with me today.I might just take Jake up town today to get shoes put on him.
__________________
05 3500 QC 4x4 dually NV5600 Smarty TNT/R PoD/MP-8 F1 inj. & springs Floor It stage 3 HTT ATS Fass ARP South Bend Fluidampnr 2 01 3500 H.O. 4x4's w/flatbeds,Fass hpfp95,edge ez,RV275's |
#37 |
Do I need to run CI oil in my 03?
__________________
03 CTD WHITE,6 SPEED MANUAL TRANS, 4WD, LINEX LINER & FASS95 BONE STOCK FROM THERE. |
#38 |
No! 08's and newer!
RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty/Pulsed Adrenaline - Mach 6's - BD Twins - Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - LazarSmith Bars - TC Lockup Switch - RAD - 3rd Gen Brakes - Fluidampr - DSS - 315/70/17 Pro Comp Xtreme A/T's Best Dyno - 628 HP/1266 ft-Lbs. Best 1/4 Mile - 12.72/105.94 - (7460 lbs) |
#39 |
RJ, I think you were thinking CJ instead of CI.
![]() CJ oil is required in the '07.5s and up (anything with the 6.7). You can run the CI oil in anything of the 5.9s.
__________________
Maroon 2001 2500 QC 4x4 SB SO pumped HO 6-speed 285/75R16 BFG Mud Terrain T/A KO, Smarty, TST Powermax3, KSB1-1, DD2s, Autometer EGT/Boost, Westach Fuel Pressure, Amsoil EaAU4091 |
#40 | |
Quote:
http://www.johndeere.com/en_US/parts.../oil_0w40.html http://www.johndeere.com/en_US/parts...s50_15w40.html I've been running the 0W40 in my 2007.5 for the last two oil changes with great results. Greg
__________________
2007.5 Dodge RAM 3500 Laramie MegaCab 4x4 SRW Laramie 2FH Pkg, 6.7L CTD, 68RFE Auto, Electric Blue Pearl Coat, Leather Trimmed Bucket Seats in Slate Gray, Front Hood Protection, Anti-spin Differential, AM/FM/cass/6 disc CD w/SIRIUS Satellite Radio, Clearance Lamps, Under Rail Bedliner, Single Rear Wheel Group, Trailer Tow Mirrors, Power Sunroof, Diesel Exhaust Brake, EDGE Insight, 20x9 Ultra #214 Chrome "Grinders" wrapped in LT305/60R20 Wrangler SR/A's. MegaCab Member #98 |
#41 |
Does anyone have and ZDDP numbers for the JD50 oil?
__________________
03 3500 QC DRW 4x4 6spd HO-4" PRXB w/04.5 down pipe, MBRP 304 Duals, Commander/X2 Race, Flux 1's, Icebox, home brewed intake horn, ported HE351, Turbosmart, leveled, 5100's, Dynatrac Freespin hubs, DSS, Reese Signature 18K 5ver 98.5 3500 QC 4x4 24v 5spd-SOLD 94 2500 4x4-SOLD CJ Juggy-Goes really fast, goes really slow, lots of smiles per mile "Madness takes it's toll....please have exact change ready" |
#42 |
Note to self.... Don't answer posts that you read without your reading glasses!.
![]() That would require an Oil Analysis on a virgin sample. Pretty hard to find....I imagine? But a used sample with the mileage used would be equally valuable, IMO. What specs are listed here.... are rather impressive. (I was not real familiar with this oil till this thread). Appears to be a high quality, non synthetic oil. Only thing I would rather not see is a TBN so high. http://www.deere.com/en_US/parts/par...s50_15w40.html RJ |
#43 |
Greg
From what I read the 0w-40 doesnt meet CI-4. Thought we needed at least that? The 15-w40 looks like good stuff. Bobtheoilguy.com might have a ZDDP reading for ya.
__________________
2006 Dodge 2500 4X4 QC/SB 5.9 I6 Line-X with Black Steel Tool Box, MBRP muffler, AFE Stage 2 Dry with CFM+ intake horn, Commander w/ FP kit, Amsoil BMK11, Smarty Jr, Pioneer AVIC-D3 w/ BT-IPOD-BU Camera, Polk Speakers and Raamat, Kore Race Steering damper. HAIL PURDUE! |
#44 |
#45 |
I love the oil thingy.... I think I will switch to JD.... U cant get the Premium Blue Classic anymore.... (in cali)
but by looking at http://www.turbodieselregister.com/TDR57_Oil.pdf, I might switch to syn... and use Rotella Syn 5W40... but 5W40 is for cold weather, right? And is the Rotella Syn from the TDR report still the same one they sell right now? What is Rotella T6? (xxx - i started another separate post...) What about ZDDPlus mixed w/ regular CJ-4 Premium Blue? Good combo? Isn't syn better for the turbo too? thx
__________________
2007 RAM 3500 4x4 5.9l QuadCab ShortBox Toyo285/75/17 SRW Carli Performance 2.0 |
| Thread Tools | |
| Display Modes | |
