#1 |
So I got 315's. Now I have rubbing issues....
I knew I would have issues with the 315's rubbing. Now all I need to figure out is how to stop them from rubbing.
I am installing a 2" leveling kit next week. So that will hopefully help inner fender well rubbing. Guess my question is, will a set of 2" spacers fix the problem or will they then rub the fenders? I am running the stock 16" alloy rims on my truck. The tires are rubbing on the lower and upper control arms. Thanks! Paul
__________________
2001.5, Blue, 2500, 4x4, QC, 6-Spd, LB. 1991 Nissan 300ZX TT. 180K. 5-speed. 1998 Pontiac Grand Prix GTP. 160K and still going. 1984 Nissan 300ZX AE Turbo, Blown engine. 1995 Honda Accord. Wife's Daily Driver. |
#2 |
I ran 315s on my 02 with a leveling kit before I did a "Big Brake" 03 rotor install and they rubbed a little on tight turns. I don't know what effect a 2" spacer will have but if I had to make a decision on rubbing or a 2" spacer, I would put up with the rubbing. It wasn't that bad.
__________________
2002 Ext cab SB, Auto trans, Boost, EGT, FP, trans temp A pillar gauges, Almond Pearl, 315x75Rx16, Ranch hand bumper, OBA, air horns, tinted, 4" exhaust, K&N + cold air |
#3 |
Deal with the rub or get aftermarket wheels. Don't do the spacer. It will put extra wear and tear on the front end. It's like holding a 100# barbell to your chest and then holding it straght out. Thats what the front end will feel.
__________________
Bill 01 2500 quad cab 4x4 Add ons: Quad XZT+, AFE Stg 2 w/Amsoil Filter, Suncoast triple disc, 4" magnaflow turbo back, Airdog 100, Diesel Dynamics stg II injectors, AGR Steering box replaced with RED HEAD STEERING BOX 2/27/10, DSS |
#4 |
I put 4-link bars from an '06 on mine. They are thinner and boxed, without the big lip on the bottom edges. Took away ALOT of the nasty part of the rubbing as I have a moderately aggressive tire. I had to redrill the top hole because the upper arms are like 9/16" shorter, but that wasn't hard. I'm also running '06 wheels with too much offset, I have been needing '00 and newer axles (which are now sitting in the garage awaiting a Powr-Lok and new parking brake cables.)
__________________
1998 12 valve, 5-speed, Quad-Cab, short bed, 4X4. #10 plate, 370 injectors, HTT 62/14 turbo, 4" exhaust, K&N intake, rear locker, Isspro E.V. series boost and pyro, US Gear brake, homemade deer/elk buster with winch and lights, 35X12.50R17 Pro-Comp Extreme A/T's on 2006 Ram alum. wheels. |
#5 |
Would H2 rims help me at all? Thanks! Paul
#6 |
yes, h2 wheels and 315s will fit with no rubbing what so ever. even without the 2" lift.
#7 |
Sweet. Thanks guys for all the help!! Paul
#8 |
I've got 315s on hummer rims and there is no rubbing except for full-lock and that's only a little bit. Those are 17" rims, though, and might not fit your present tires....
__________________
<---My previous oil burner "Bombs delivered on time or your money back!" ------------ '01 2500 SLT Laramie QC LB 4x4 Auto 3.54 gears 230K miles. Goerend w/billet input shaft/ low stall TC/ 2,3,4lockup+switch, 4" exhaust, Edge Juice with Attitude, Superchips 3705 Tuner, Walbro 392 with Swagelok bypass, Yokohama Geolandar 315/70R17s on 2006 H2 LE Alcoa wheels, '03 front brake conversion, PSC Steering Stabilizer. '09 Northstar 850 SC XB popup slide-in camper Semper Fidelis! |
#9 |
You need to move the wheels outward to stop the rubbing, not down, which is what the levelling kit will do.
I haven't seen any increased wear on my truck, either as stated above. Heavier and larger diameter tires and wheels will do that on their own. The Hummer wheels look really nice on our trucks IMO. Kurt
__________________
Kurt 2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Laramie Plus Arctic White,3.54's, Camper/Tow, Stull SS Running Boards, A.R.E. Cab-Hi Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,Power Service, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug,DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, new intank LP @80K, 95K miles. Good judgment comes from experience, which often comes from bad judgment: W. Rogers Support Our Troops! NRA, MSBL, BYO, GSP |
#10 |
Well i don't know what smoke i was crackin on. My new tires are 16's so.............H2 rims won't work for me now unless i get new tires.
I guess i should have planned better. Anyone know of a decent set of 16" rims that will work for me? |
#11 |
What about these. You think these will put me out farther than the stock rims??
http://cgi.ebay.com/ebaymotors/16-X-...fAcces sories |
#12 |
I had this problem on my '01.5 when I added 305/70/16's to the stock 16 x 8 wheels. It instantly cleared up when I switched to 16x10 wheels with 4.5" backspacing.
These wheels beefed up the stance of my truck and kicked the tires outboard about 2". Ted
__________________
2001.5 2500 QC H.O. 6spd. 4x4 , 2" Rough Country leveling kit, spray-in bedliner, Westach FP Gauge, pillar mounted 3 gauge pod, 305/70-16 Wild Spirit ATs on Pro-Comp 1069s, Bushwhacker Extend-a-Fender flares |
| Thread Tools | |
| Display Modes | |
