Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-18-2010, 09:07 PM   #1
crowbar
Smarty Jr Not Working
I have my truck programed to towing and this morning I wanted to change to performance and the screen would not come up. The lights on the dash did their thing but the screen was blank.I haven't used the Smarty Jr in awhile.I came in and reprogrammed the Smarty Jr to the new program thinking it might wake it up the screen came up and it reprogrammed fine.Took it back out to the truck and still no screen .Any ideas on what is going on? I thought it may be the cable.Anybody had this problem?I sent a e-mail to Mad and they said someone in my area would contact me but nothing yet.
__________________
2004 2500 Auto Quad SB
crowbar is offline   Reply With Quote
Old 06-18-2010, 09:23 PM   #2
AH64ID
AH64ID's Avatar
Thats not an issue I have heard of yet.
When you plugged it into the computer the screen worked?
__________________
'05 3500 SRW 4X4 QC LB NV-5600
Smarty UDC Custom Tuned
AH64ID is offline   Reply With Quote
Old 06-18-2010, 10:07 PM   #3
rockcrawler304
rockcrawler304's Avatar
I'm sure you checked but were both ends of the cable plugged in tight?
Is there anybody in your area with a dodge you can plug it into to see if it is related to the Smarty or just your truck?
__________________
2006 Atlantic blue Mega Cab 2500 4x4 6 spd. 3.73's CTD 325/610, Silencer Ring gone, Amsoil EAA189 Air filter, Air Box mod, Smarty Jr (SW2,TM3, TQ Default, PoD99), Autometer factory match gauges, Fuel Tank Vent Mod, Muffler gone, Amsoil Oil bypass, Ravelco
80's Chenowth 2LWD 2 seat sand rail (Rebuilding!!) Turbo Subaru power Installed!!
rockcrawler304 is offline   Reply With Quote
Old 06-19-2010, 07:45 AM   #4
crowbar
Smarty Jr Not working
I checked the connections and everything is tight. I tried a hand held code reader in the emc plug and it worked fine. I guess I'll wait and see what Mad comes up with dealer wise in the Southern Maryland area. I am still leaning to the cord maybe having a bad pin. Anyone know what pin powers the Smarty Jr?
Thanks for for your help
Old 06-19-2010, 12:23 PM   #5
soulezoo
DTR 1st Sergeant
soulezoo's Avatar
First time I've ever heard that issue. Considering what you have said, I would lean toward a bad pin in the cable or the box.
__________________
"The Punisher" 2004 3500 QCSB Laramie 4x4, CA emissions SO 235hp, 3.73 posi, Peak Performance BB Twins, Almost stock
DTR "Twins" Club Member #1
11.89 @ 119.2 mph
1/8 mile= 7.76@94.94 mph
900.86 rwhp/1689.76 tq on #2 @ Left Coast Diesel 21 AUG 09
SAC member #9
soulezoo is online now   Reply With Quote
Old 06-19-2010, 01:26 PM   #6
bansh-eman
bansh-eman's Avatar
See if you can get ahold of Bob http://shop.wagnerandassociates.biz/main.sc
he might have an answer for you.
__________________
Pour one for my homey... Sold my truck below :( Now I am driving a Ford F-150
~Black 06 2500 HO 48re 4X4 Big Horn Quadcab SLT~
-RevTek 4.5in Lift w/ Bilstein 5100's
-Toyo Open Country M/T 35x12.50x18
-XD Addict 18x9
-SMARTY Jr.
-GDP MK2 - 2 Micron Fuel Filter
-Amsoil Oil Bypass
-PSC Steering Brace
-Bilstein Steering Damper
-Thuren Adjustable Track Bar
-N-Fab W/W 6 Steps
-Jimmy Jammers
-Ravelco
-Bush Wacker Pocket Flares
-Ranch Hand Bullnose w/ PIAA 520's
bansh-eman is offline   Reply With Quote
Old 06-19-2010, 02:31 PM   #7
cbrahs
cbrahs's Avatar
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 41
the cigar lighter and OBDII port use the same fuse. check your fuse. if the JR screen lights up on your PC and does not light up when connected to the truck then the OBDII port is not getting power. check fuses first
__________________
2011 3500 CC LB Laramie (now a dually), 19.5" visions w/ 245x70x19.5 toyo's, S&B CAI, weathertech, Ravelco, cabin filter mod, 120 gal aux tank w/FASS 150 xfer pump, B&W, T-Rex steering brace, Pro Tech, mag-hytec's
My Marine son protects your honor student
Disabled Combat Rescue USAF Vet.
September 2010 TOM Winner! (with the bucket)
SAC Member #1
cbrahs is offline   Reply With Quote
Old 06-19-2010, 04:38 PM   #8
crowbar
I did a ohm test on all the pins and one is not working.
Thanks for all the replies.
Old 06-19-2010, 05:00 PM   #9
EverydayDiesel
EverydayDiesel's Avatar
hook it up to the usb cable (computer) without the odb2 and see if the screen comes on
__________________
2007 6.7L A6 - !DPF !EGR, Smarty, Edge Insight
2001½ CDT 24V Auto
Mexi-block, BFAF & shield, Silencer ring lost, Juice w/Attitude, FASS Pump with Air/Fuel Separator
Please give a few bucks to help this site!
EverydayDiesel is offline   Reply With Quote
Old 06-19-2010, 05:12 PM   #10
crowbar
I did that and screen came right on . The pin on the cord if you move it back and forth it will make contact ,it is open under the molding of the plug on the ecm side.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
