Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 10-19-2008, 01:48 PM   #1
Krob
Krob's Avatar
Signs of VP44 death closing????
Alright i now have a Quad Xzillerator sitting at my house for me to play with when i come home n leave. However i dont want to kill my VP44 while i am home.
What are the signs that your vp44 is starting to get old. Ive got a 100k on truck, walbro pump, and life hasnt always been all that nice to this truck. THoughts?
THanks ROb
__________________
Stabled in my Fathers Barn
01, 2500 Laramie Ext Cab Long Box, 6 speed 3:55 posi
Walbro-GFS 392, Timbo APPS
FBD 4in w/ muffler exhaust
Auto Meter Gauges
XZT+, 90-130hp Injectors PO (not sure now), Boost Elbow (set at 30psi)
And an Xzillaraiter sitting on the shelf waiting to be put on
MIA Silencer Ring
Krob is offline   Reply With Quote
Old 10-19-2008, 03:23 PM   #2
johnh
johnh's Avatar
THanks ROb
my FCM went at 181000 , who knows how long the rest of it would have lasted. in my case ,i shut it off to refuel and it wouldn't restart......
__________________
01 3500 ho 2WD;4 inch exhaust bully dog stage 3 inj edge comp(removed hybrid hx 35/40 8/25/04) dyno 419.2 hp 891.8.torque w/stage 2`s on a dyno jet 6/25/03 ,htb2 turbo installed 8/25/04, not a dually any more,conversion done in 04... added home designed propane march 07 (to improve mileage) new vp 44 from industrial injection 3/july/07 181000 miles, removed stage 3 injectors ,reinstalled stage 2 to try to control EGT's better.new head gasket by industrial injection 17 dec 2010
johnh is offline   Reply With Quote
Old 10-19-2008, 03:28 PM   #3
Krob
Krob's Avatar
I really dont want to know horror stories...i am already scared, from listen to all of you.
I know the codes, i know of the difficulty starting, power lose, what else....Fuel milage dropping????
Old 10-19-2008, 05:15 PM   #4
Kenworth
My only sign was dead pedal. It started that I'd only have trouble once or twice in a 200 mile trip. Then it got so bad I'd have dead pedal even pulling out of my driveway.
__________________
2001.5 2500 Quad Cab Long Box 4x4 Sport
Raptor 100, AFE Prodry, Edge Juice With Attitude, DDP 150's, 47RE Built By Me
Kenworth is offline   Reply With Quote
Old 10-19-2008, 06:06 PM   #5
13ALPHA
13ALPHA's Avatar
I've heard of dead pedal, but mine failed instantaneously, just quit like that while driving, no warning prior or change in driving.
__________________
Scott
1995 QC LB 4x4 Auto, 35x12.50 BFG ATs, BHAF. 240k mi
13ALPHA is offline   Reply With Quote
Old 10-19-2008, 06:17 PM   #6
P.J
P.J's Avatar
dead pedal, decides to never start again after a routine filter change..........stranded on the side of the road waiting for a tow truck.
P.J is offline   Reply With Quote
Old 10-19-2008, 07:53 PM   #7
Krob
Krob's Avatar
thanks Rob
Old 10-20-2008, 06:00 AM   #8
blackcloud
blackcloud's Avatar
I could tell for about 3000 miles that something wasnt right, crusing on the interstate truck felt like it was surging, then one day i got the dead peddle and she was gone. I check my codes about every two weeks, if you turn your key (not starting the truck just to the run position) three times your codes ( if any) will appear in your odometer screen
__________________
New truck: 2001 quad cab long box 6spd 4x4, ez,Hypertec max energy, bhaf, straight pipe. 2" leveling kit 315/75/16 Good Year Dura Tracs on stock wheels
Old truck:1994 Dodge Ram 2500 4x4 Cummins 5.9L, regular cab long box, 5" exhaust, pyro and boost gauges, South Bend clutch 13 in. OFE,silencer ring, what silencer ring? BHAF, #0 plate, Scheids 035 DV's, Head studs, timing @ 13.5*
blackcloud is offline   Reply With Quote
Old 10-20-2008, 06:38 AM   #9
Krob
Krob's Avatar
Yeah, i know that trick, i am just debating on weather or not to tap it while i am home or wait till i come bac from being downrange when i have a pocket full of money and can afford to replace the VP.
Truck realy hasnt shown any signs, last couple of tanks when i was home mpg was a little cruddy and it was throwing some codes but i think that was from the XZT+ not taking the tunes from a vista computer.
SO thoguht?
Thanks ROb
Old 10-20-2008, 12:40 PM   #10
johnh
johnh's Avatar
no horror story ,just the facts ....most vp 44's will go untill they fail with no warning.....
Old 10-20-2008, 03:05 PM   #11
Krob
Krob's Avatar
yeah and thats kinda the horror. Kablam and your dead on the road.
Old 02-22-2009, 04:53 PM   #12
dhughe2
dhughe2's Avatar
What exactly happens when you get the dead pedal, and if there is a code, shouldnt it trip the MIL?
__________________
2002.5 Dodge Ram 2500 CTD QC 4x4 Long Bed, Light Almond Pearl, 47RE transmission, Trailer Tow Group, Camper Special Group, 3.55 Axle Ratio, LT285/75/R16 Goodyear Wrangler SilentArmor Tires, 771XV Viper Alarm/Remote Start. Luverne Side Entry Steps, Fass DDRP, ISSPRO Boost, Pyro, Fuel Pressure. Muffler and Silencer Ring MIA
Maryland Chapter 33
dhughe2 is offline   Reply With Quote
Old 02-22-2009, 06:11 PM   #13
j-fox
My check engine light never came on.
I was down on mileage about 2-3.
First thing I noticed was no timing advance climbing a hill. ( it was very quiet, like a gas motor), then next hill it had huge advance. Then dead peddle. Drove it for 6,000 miles!!! If I kept it above 60 there was no dead peddle!!!
Finally it was so unpredictable, I bought a Blue Chip, and it has been great.
It did show code 0216 for a long time.
__________________
2005 4 door 4X4 6 speed.
j-fox is offline   Reply With Quote
Old 02-22-2009, 07:14 PM   #14
ironworker68
I bought my truck used right after the original owner had the VP 44 replaced. I installed a low fuel pressure warning light and new transfer pump. 70,000 miles later the VP died with no warning other than a rough idle after pulling out of my garage. No warning at all. Just dead.
Vented my frustrations earlier on a different thread. I am going to run 2 cycle oil in it after I get it back this week. It's the only thing left to try. If it fails again...it's gone.
__________________
"Maxine"...2001 Dodge Ram 2500 24 Valve 4WD, Regular Cab, 8 ft. bed, 6-speed manual, Bullydog Torque Dog, K&N Filter, 3.54 gears, low fuel pressure warning light.
She loves to eat Carter lift pumps like M&Ms.
ironworker68 is offline   Reply With Quote
Old 02-22-2009, 08:57 PM   #15
Kennys
Mine acted up for almost 100K miles. It started on cold starts, lots of blue smoke. It was as quiet as a gas engine for about a mile. It would only run 35 until it got warm. Then it started a little surge. This went on for years and a lot of miles. It died in the yard when I changed the fuel filter. Nothing I did would get it started. I had already ordered a new VP44 when it did fail. Could not have been in a better place. Always worried about failure on long trips but it didn't happen. The new pump has over 200K on it with no problems at all.
__________________
98.5 White, 3500 Laramie SLT, Quad Cab, 6 Speed, 4.10 LSD, Fog Lights, Alarm, Tow Package, Edge EZ/Boost Elbow, Westach Boost/EGT, Fuel Pres., Trans./Diff. Gauges on A Pillar, 275 Injectors, No Muffler, 90 Gal. Fuel/Toolbox Combo, Fiberglass Running Boards &amp Ground Effects, Amsoil Remote Bypass, AFE Mega Cannon, Tekonsha Brake Control, 33ft. Travel Supreme 5th Wheel, 36ft. Trail Master Gooseneck, Cobra 29, Kenwood TS50 &amp TR751A, 400K miles.
Kennys is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
