New Amsoil tranny oil for the NV5600
Amsoil just came out with synthetic synchromesh transmission fluid called MTF 5w-30 for the NV5600. http://www.amsoil.com/StoreFront/mtf.aspx
MikeyB
MikeyB
Well then dosen't the transfer case take the same fliud?
I'm about due an oil change in my transmission, don't know if I'll change to the new oil or not. I've been running Amsoil 10 - 30 motor oil since about 25k, I'm nearly at 225k now with no problems at all, shifts fine to me.
Pennsoil Syncromesh (also Quakerstate Syncromesh) is the factory Dodge fill.
http://www.pennzoil.com/products/gea...cro_fluid.html
At bottm of the web page is the data sheet. Just click for the specs.
Redline has MTL which meets the requirements for the 5600 also. Cheapest on the web is:
http://www.myoilshop.com/AutoPrds.html
The Transfer Case uses ATF. Either Amsoil ATF or Redline C+ exceed the standard.
Put 5 qts. of the Amsoil MTF in yesterday. To be honest, it shifts the same as with the Amsoil 10w-30 motor oil. Put a little over 350 miles on it today with about 24k behind me.
EB
EB
