Fuel fill hose
Fuel fill hose
I was filling my truck for the second time since buying it, and noticed when the tank was getting close to full, there was a steady stream of fuel pissing on the ground ($$$). After I got home from work that day I crawled under there and found the hose the fuel was coming from. Someone had taken a piece of clear hose and after cutting a hole in the main fill hose, inserted the clear one and silicone the heck out of it. I can only think that a PO did this as some kind of extra overfill device . Or is this some kind of mod that is done to these trucks???
I don't have a pic handy, but I can take one
I would agree with you regarding it's something that a previous owner did, although why I don't know.
It's not a mod I've ever heard of being done either. Maybe the guy filled up at a place the automatic cut off on the pump handle didn't work.
Bob, you nailed it! The previous owner must have had an aux tank. Thanks
I am cheap, so I just cut the hose short and stuck a bolt in it and used a hose clamp. So fuel spillage now!
jtjpike
06-16-2011 08:14 PM
92GhostRyder
07-02-2008 12:43 AM
Bluedeviltorque
04-20-2005 07:49 PM
