conversion problem on 92 d350
Old 07-22-2014, 09:37 PM
td3620's Avatar
Question conversion problem on 92 d350
I made my 92 d350 4x4,i didn't everything right as far as I know. Went off by some threads on here.but ran into a problem. My motor is sitting to high and not sure what I did wrong. I can sent pictures to someone email or by phone.im not sure how to load them on here yet. Thanks Wesley here my number (940) 445-0270 or my dad (Thomas) at (817) 597-6780
Old 07-22-2014, 09:41 PM
mknittle's Avatar
Post some pictures. It is the only way we can all be on the same page.
Old 07-22-2014, 10:19 PM
Received 1,331 Likes on 862 Posts
Did you use a cross member from a cummins truck...or from a gasser? If it's from a gasser then you will have to open up the holes for the motor mounts, and I believe lengthen them...to lower the motor.
If you need pic posted you can PM me for my e-mail. Or my E-mail might be in my profile...can't recall???
Old 07-22-2014, 10:26 PM
td3620's Avatar
got all my parts off my parts truck .was a 91 dodge diesel w250.and thrashingcows I went off most of your stuff,and ill email you pictures
Old 07-24-2014, 07:39 PM
Here are the pics Wes sent me....take a look and see if you can help spot his problem.
Me I think the problem lies in the rubber mounts. The pass side is backwards...metal sticking off should be towards the front of the truck. And the drivers side is upside down...the metal pieces are in the right orientation.
Old 07-24-2014, 07:40 PM
Old 07-24-2014, 07:42 PM
Old 07-24-2014, 07:43 PM
Old 07-24-2014, 07:47 PM
bryson711's Avatar
I think your right cows
Old 07-24-2014, 10:05 PM
mknittle's Avatar
The crossmember looks like it is where it is supposed to be.
The rubber pads do look awfully thick.
Old 07-24-2014, 11:38 PM
PapeCAT's Avatar
Please inspect and / or show pics of the cab mounts (to check if they're low/flat)
Also, when you had all of the crossmembers out, any chance the frame rails bent?
Those mounts look like standard Anchor brand mounts you can get at Oreilly's, which I've used many times with no issue.
Old 07-24-2014, 11:48 PM
Good suggestion on the cab mounts. But even if they were toast, I can't see them dropping the cab several inches?
I agree they do look like anchor mounts. Same ones I have used as well.
Old 07-25-2014, 06:14 AM
Received 2,379 Likes on 1,572 Posts
There is a dimple in the engine crossmember that a bump in the engine mount rests in to get the orientation correct, if I remember right.
Old 07-27-2014, 09:21 AM
td3620's Avatar
cab mounts are fine.
frame aint bent,i made sure of that.
yes they are from ol rileys
Old 07-27-2014, 08:49 PM
mknittle's Avatar
I can't see anything wrong. at least nothing that sticks out at me.
we have one that doesn't have the sheet metal on it and comparing it to your pictures. they look the same.
Quick Reply: conversion problem on 92 d350
