Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 07-03-2012, 02:14 PM   #1
willroach
willroach's Avatar
What is the purpose of this?
Hey Folks, one of the PO has installed a heater hose that runs from the radiator area, thru the engine compartment and down the frame rail. The other end isn't connected to anything and just hangs off the frame rail almost like a drain. Any idea what its purpose is for? I appreciate the help!
Click image for larger version
ID:	39546   Click image for larger version
ID:	39547   Click image for larger version
__________________
Will
'08 2500 95K
'89 w350 155K
willroach is offline   Reply With Quote
Old 07-03-2012, 02:24 PM   #2
simplysmn
simplysmn's Avatar
Maybe some kind of spray bar for the radiator?
__________________
2008 2500 Sold / 2011 3500 Sold
1985 crewcab w350 4x4cummin's swap
wifes hotrod 2012 Jetta sport wagen TDI it's a little Rocket
lost but not forgotten 1967 vw speedy the bug died a hot death on 5-17-10 12 noon
Ashes to ashes, dust to dust, if it wasn't for fords..... my tools would rust!
FORD Ford Owner's Recommend Dodge :)
simplysmn is offline   Reply With Quote
Old 07-03-2012, 04:03 PM   #3
thrashingcows
Now that is a good guess I think....Hook up some water into the line and see if it drips, or mists in front of the radiator. Could have been for extra cooling?
__________________
1984 Dodge Crewcab, D350, 1 Ton SRW, long box, 89 CTD, stock with 283K Kilometers, 366 spring, 1/8 timing bump, Fluidamper, Isspro Tach/Boost and Pyro Gauges, KDP killed, no I/C, piston lift pump, 2nd gen fuel heater, 3" exhaust, 96 NV4500 5spd with filter kit, Dana 60 with open 3.54's.
thrashingcows is offline   Reply With Quote
Old 07-03-2012, 04:07 PM   #4
simplysmn
simplysmn's Avatar
After looking at it that was the First thing that came to mind spray bar
Old 07-03-2012, 07:36 PM   #5
willroach
willroach's Avatar
Well i took a turkey baster and forced some water into it and sure enough it acts like a drip bar running the water down about four areas on the radiator. A PO must of had to have a way to force water into this while driving. Makes me wonder how much better it would cool the motor down.
Old 07-04-2012, 01:03 AM   #6
jimbo486
jimbo486's Avatar
Sounds like a water misting or drip system to me. My dad setup a similar system on his '86 F-350 6.9L with a rubbermaid tote with a lid in the bed. It was working well pulling our 33ft. Tailgator up the 395 to Mammoth until heat from the exhaust manifold melted the hose .
__________________
"My name is Jim, but most people call me.... Jim"
- Blazing Saddles -
- '90 D350 "Rust Bucket Hunter" -
- Giles' 12mm VE - Airdog II 165 - XDP sump - Bradley's Diesel 5x.013s (68-70lpm) - Powerstroke I/C - Fluidampr -
HTT Super 40/35 'gated 14cm - 4" exh. - '01 NV5600 - SB Con OFE Clutch - D70 3.54 -
263HP / 610ft. lbs. (Aug. '10: prior to Giles VE, AirDog, XDP sump, 5x.012s and Powerstroke I/C)
Updated numbers: TBD
Up and Cummins
- Paint -
jimbo486 is offline   Reply With Quote
Old 07-04-2012, 11:23 AM   #7
NE frmhnd
I'm thinking that might not work so swell around here. You can drive a couple hundred miles and not touch pavement.
Any idea how much water you would need to put through it to do much good?
__________________
"Merle" 90 D250 LE, pretty well stock, regular cab longbed, rust-oleum royal blue, auto, slow rear gears. Temporarily, unnecessarily, ditched the condenser for an aftermarket trans cooler.
"Owen" 90 W150 LE, regular cab longbed, 318 TBI, A518, silver on dark blue 2-tone, needs trans help. And paint.
1990 Isuzu Amigo. Needs a diesel.
2 years in Nebraska.
NE frmhnd is offline   Reply With Quote
Old 07-04-2012, 01:10 PM   #8
j_martin
j_martin's Avatar
1 quart a minute would cool about 130,000 BTU/hour, assuming water at about 80° evaporating in contact with the radiator.
That's significant, and 15 gallons would cool it for an hour at that rate.
__________________
93 D350 LE extended cab. Set up to pull recreation double.
To fish or not to fish? What a stupid question.
j_martin is online now   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
