Thread Tools | Search this Thread | Display Modes |
#1 | ||
__________________
1995 AUTO 4X4 cummins , twins , 140hp sticks ,colt stage 3 , 215 pump , 24 dv's , built trany , dana 80 and some other junk 1994 3500 2wd nv4500 215hp 1991 reg cab 2wd 5.9L shiny wheels and stacks all run on B100- b50 for winter 1981 dodge 1500 4x4 18inch lift 383inch gasser diesel/auto tech for 14 very long years |
#2 |
doodddddddd
![]() I'm at work for 3 weeks now or I'd be on hand. sorry brother.
__________________
Luke --------------------------------------------------- '06 Ford F450 CC Lariate 37" Toyos '98 Freightliner COE C12 13spd LWB '90 VW Jetta 1.9TD coupe wolfsburg '73 Chevy RS/Z-28 454 M21 |
#3 |
holy crap dude that sucks...... if i didnt live way out in the sticks i'd say you could set up in my shop to get you by......
__________________
Wade 08 3500 DRW, 4X4, 6.7, 68RFE, Mini maxx W/OD software, Full deletes, GDP Big Line Kit, GDP F/W sep & 2 micron kit, AMSOIL, Mag-Hytec trans pan, DSS. DTR Mega Cab Club #357 99 2500 24V, Reg Cab LB, NV4500, 4X4, Diablosport powerpuck, FASS 95, AFE stage 2 intake, Line X, DSS. 98 Kenworth T800, 3406E Cat @ 550 Hp, 1850 Ft Lbs, AMSOIL, 13 Dbl over, 3.70 rear gears, 6 inch miter cuts I try to lead by example, occasionally its by showing others how not to do it |
#4 |
thanks guys
#5 |
That really sucks.. Hope ya find a shop to set up in.. Hope the dude ya paid to looses his nuts..
__________________
2011 crew cab dually long box stick.. soon to get some toys in it.. B&W turn over hitch with companion fifth wheel, air bags in the rear, |
#6 |
that doesnt sound 100% legal. if you have all of your paperwork in order they shouldnt be able to throw you out like that.
__________________
1997 Ram 2500 SLT Lamarie 5 speed manual Ext cab, Long Box BHAF, 4in exhaust, kdp tabbed 305,000km, autometer phantom pyro and boost gauges if it moves and it shouldnt it needs duct tape, if it doesnt move and it should it needs wd-40. Remember when owning a diesel meant you never had to worry about grade, just whether or not it was flammable |
#7 | |
Quote:
#8 |
Sorry to hear that Rob.
Now that the Landlord has evicted the lead tenant the whole space is vacant and losing him (the landlord) money. You should see if he will lease it to you directly, he knows you pay your bills. He probably had to evict you and the leaseholder as a matter of contract law. If it is just sitting there now..... maybe you can get him to do a few of those leaseholds you wanted to compensate for the inconvenience? |
#9 | |
Pickin on the wrong admin...
Quote:
__________________
1995 Dodge,280,000 miles, regular cab dually,4X4,5 speed,4:10 gears,Wastegate blocked,15 degree timing,Polyurethane control arm bushings,BHAF,KDP Tabbed,Pyro & Boost,DSS,2003 trackbar upgrade,Steerring bushing,#0 plate,3K springs,215 injectors,Laser cut DV,Con OFE. Mar 2008, Dyno: 353HP/735 Ft Lbs June 2008 Dyno:344HP/835 Ft Lbs 1978 Mercedes 450SL 1956 Chev 4 door Sedan 1977 T/A 400,4-speed 1963 Ford Falcon,2 door |
#10 | |
| Display Modes | |
