Being Towed Question.
Old Mar 9, 2010 | 03:25 PM
Dangousity's Avatar
Post Being Towed Question.
What is the correct way to Tow a 2002 4x4 Dodge diesel? Should the truck being running while any of the tires are on the ground and turning, to lube the transmission? Or is that not necessary. I really don’t know, seems like it couldn't be anything but good for the tranny.
Old Mar 9, 2010 | 03:33 PM
biododge1's Avatar
I would think the best way is to remove the drive shaft from the pinion yoke, and securely suspend them to the frame.
Old Mar 9, 2010 | 04:04 PM
infidel's Avatar
Owner's manual for my truck says to tow with the transfer case in N and if for more than 35 miles to disconnect the rear driveshaft.
Old Mar 9, 2010 | 08:02 PM
dkenny's Avatar
using a flatbed truck..or a rollback..
that's what the dealer used to tow my 2000 gas truck and its a 5 speed.
auto I would agree with what infidel wrote
just my 2 cents
-dkenny
Old Mar 9, 2010 | 11:14 PM
nickg's Avatar
tow from the rear transfer case in neutral.
Old Mar 10, 2010 | 03:27 PM
Junk Man's Avatar
The weight distribution is wrong when you tow backwards. You may end up in a ditch & learn how poorly the truck survives. But, feel free to take a video for youtube. Much more enjoyable to watch someone else screw up than to do the same thing yourself.
Old Mar 10, 2010 | 11:58 PM
Nick02Ram's Avatar
You talkin about actually towing, or just pulling it behind another vehicle?
When I towed mine I slung it from the front (only because the front hub was out) other wise I woulda wheel lifted it, since our shop does not have a rollback. But I was taught to always pull the shaft (and strap it to the frame to keep the tranny/t-case from leaking) regardless of distance just to be safe
Old Mar 11, 2010 | 08:17 AM
nickg's Avatar
pretty sure you got that backwards!, towing from the rear means the tow truck has less weight on its rear end hence not lifting the front of the tow truck, which means the tow truck is not wandering all over the road. Unless you did not strap/lock the steering wheel of the casuality, then there could be wandering issues
Ex military, here ran a recovery section for 4yrs, 5ton to 10ton wreckers, pulling heavy stuff, never saw any issues towing from either end, the end you decided to tow from only made a difference if there was something physically wrong with the veh casuality (ie hub/wheel broke/or missing)
20yrs as a Military mechanic, never seen tow from the rear an issue unless it was physically impossible, and I've seen some pretty bizarar recoverys
My two cents
when my truck got smashed by a tire (is a post on it) I was recovered backwards, was towed 30miles on the hi-way back to the garage...it never ended up in the ditch or on Ytube
Old Mar 11, 2010 | 07:23 PM
partisan1911's Avatar
What thickness of metal did you use on that front bumper? It almost looks like you built it in sections from where the break is?
Old Mar 11, 2010 | 10:42 PM
nickg's Avatar
here is a link to the whole story:
http://www.cumminsforum.com/forum/al...hevy-tire.html
Old Mar 12, 2010 | 07:02 AM
1-2-3's Avatar
Just a plain ole guy
I wonder what would have happened if that bumper would have been full of sand.
Old Mar 12, 2010 | 04:04 PM
crane 1's Avatar
I pull mine regularly 30 to 150 miles at a time with a towbar by just putting the transfer and trans in neutral with the key in the on position to unlock the steering. If you're pulling it with a pickup make sure it is running so the power assist steering helps it follow or you will have a handful
Old Mar 14, 2010 | 08:01 PM
kicker210's Avatar
i had to have mine towed and they told me that being a 4x4 and with it being the auto locking hubs that it always should be towed on a flat bed do to the transfer case would get torn up.
Old Mar 14, 2010 | 09:44 PM
nickg's Avatar
you dont have auto locking hubs, you have either a CAD or a system like the 03's which turns the front drv shaft all the time. if its in Neutral (transfercase) there would be no issues for short distances, (if towed as you see mine in the above picture) most tow truck companys (mostly cause the operator is not a mechanic) will use dollys or flat bed, to eliminate potential claims against them or to charge more to the owner because they use the . "It's a 4x4" excuse
AWD vehs like say a Ford excape or Chev Equinox, would need dollys or flat bed,
Old Mar 15, 2010 | 05:39 AM
Shovelhead's Avatar
Administrator / Scooter Bum
The three occasions that I have had my dually towed, I insisted on a flat bed truck.
I'm not willing to take a chance of burning up my Goerend's tranny.
Box5
Jul 19, 2007 06:46 PM
JWHenson
Aug 12, 2006 11:46 AM
bryan5791
Jan 1, 2003 10:19 PM
radracing
Nov 30, 2002 02:28 PM
tobyw
Oct 7, 2002 05:49 AM
