Thread Tools | Search this Thread | Display Modes |
#1 | ||
Building my own air intake
__________________
2005 cummins 2500, 4" exhaust, secondary fuel filter, auto trans, no extras its a company truck that has never seen an easy day in its life but looks almost brand new. |
#2 |
Location: Newman Lake, WA (But my home is deep in the heart of Texas!)
Here's mine......I did it years ago and it still works great.
#3 |
My filter will probably out in the open unles I can figure out a box for it, and are there any mpg gains to having aftermarket filter set up over the stock flat panel
#4 |
A lot depends on your right foot, but yes the aftermarket filters will yield a little better economy due to the higher flow and less restriction.
__________________
2002 white 2500 Quad cab 4X4 short box automatic (built by local shop). Quad Adrenaline with a Pulse , Jammer Stg 4 nozzles, VP44 at 98K, BD super B single, BD X Flow intake, Glacier Diesel Fuel Boss, 4 inch exhaust, intake, cowl induction hood. Centerline Wolfer wheels with Dick Cepek 33/12.50/17. Leveling kit. Full synthetic in every cavity. 462.48 HP 969.63 TQ Link to some pics. http://s433.photobucket.com/albums/q...rkenman/Dodge/ |
#5 |
Is it just me or is the exhaust stud loose on your #4 cyl?
__________________
2001 2500 CTD, H.O 6 Speed, 4x4, Edge Comp, O-ringed & ARP'd Head, FASS, 2 in. Level, Top Gunz Control Arms, Thuren Track Bar, Eagle Alloy 058 wrapped in 285/70/17 Destination A/T's, 3rd Gen front brakes, 100HP injectors, Hood Stack, Isspro Gauges, South Bend Con FE, DSS, Firetruck horns... Just need a turbo now! |
#6 |
#7 |
There is a template on here somewhere that I used to make a heatshield for my BHAF. It works pretty good but you should make a cardboard one to really make it fit better.
One filter is probably enough, you can only suck so much air thru a 4 inch inlet.
__________________
Kurt 2001.5 2500 QC LB 4WD H.O. 6-SPD SLT Plus 3.54's, Camper/Tow/Plow, A.R.E. Canopy w/ SS Vanguard rack, Southbend clutch and hyd.,TIMBO APPS, BHAF/Heatshield, MBRP 4" TBE, FP Gauge, Femco E-Z Drainplug, DSS, Thuren Trac Bar, 2" leveling kit, P/H Tow Mirrors, PBR, 128K miles. FASS LP "When I was younger I could remember anything, whether it happened or not." Mark Twain Support Our Troops! NRA, MSBL, BYO, GSP, BOLTS, Southpaw, CDC* *Cracked Dash Club |
#8 |
Just what I did.......removed the factory stuff, added the K/N to the bellow, then used cardboard to make a template of a heat shield which I eventually fabricated out of 316L.
#9 | |
Quote:
Oh yeah....my "Cold Air intake" cost me a total of 40 bucks.......price of the filter.
#10 |
good job tanderson.nice to be resourcefull.
__________________
02 2500 slt laramie qc 4x4 long bed cummin's auto,k&n filter kit,4" turbo back exhaust,mia silencer ring,edge ez,vulcan draw straw II,airdog fp100,autometer fuel pressure gauge,issopro egt,tran's temp, and boost,2" leveling kit,dss,dt adjustable track bar h2 wheel's waiting for tire's,custom lower control arm's.waiting for nicer weather |
#11 | |
Quote:
#12 |
could you run a bhaf in a set up like that? and is that just the k&n filter from their cold air kit?
__________________
2002 2500 HO Sport, 4x4, NV5600, South Bend DD3250, Edge Juice w/ Attitude HOT unlocked, DDP 100hp sticks, S300 turbo 62mm, Air Dog FP100, ARP Head Studs, MBRP 4" straight pipe, BHAF w/ Outerwears & stainless heatshield, KDP Killed, 35's, 2" leveling kit, 450 rwhp 900 ft/lbs 91.5 W250 LE reg cab, Getrag G360, fuel screw just a hair from runaway, timing bumped, 3200 rpm spring, Southbend Clutch, hood stack, KDP killed |
| Display Modes | |
