Leveled Mega Cab Pictures
Old Aug 17, 2008 | 10:17 PM
ktmrdr85's Avatar
I was thinking about getting a Mega Cab. The only problem that I had over the Quad Cab was that I personally think that the Mega Cab doesn't look too good without it being a little higher than stock.
The problem is that all that I would be able to afford would be a leveling kit, and if I think that the truck needs to be higher to look good, then I'm SOL for a while.
Please post pictures of trucks that are leveled with 33s-35s and specify which size tires you have.
Thanks in advance.
Old Aug 17, 2008 | 11:09 PM
TV Truck's Avatar
I just leveled mine a month or so ago,but don't have any pictures yet. I have stock rims and tires, but will try to get a pic up for you tomorrow.
Old Aug 17, 2008 | 11:53 PM
Festus's Avatar
2" Revtek on 33's:
Old Aug 18, 2008 | 01:24 AM
95ram's Avatar
Here's some pics of mine.
http://s281.photobucket.com/albums/kk216/95_ram/
Old Aug 18, 2008 | 07:50 AM
Fisherguy's Avatar
Originally Posted by 95ram
Nice job on the H2 wheels. Those the chrome ones?
Old Aug 18, 2008 | 09:22 AM
rock crawler's Avatar
I leveled the front but the rear is still too high for my taste.
Old Aug 18, 2008 | 04:03 PM
DG527's Avatar
Not a great picture, but you get the idea.
https://www.dieseltruckresource.com/.../IMG_00332.JPG
Old Aug 18, 2008 | 04:06 PM
CrashCade's Avatar
Did you lower the rear on this?
Old Aug 19, 2008 | 01:17 AM
No, it's just the angle of the pic. If you look at it from the side it still looks high in the back.
Old Aug 19, 2008 | 01:55 AM
95ram's Avatar
Thanks. No they are the standard H2's.
Old Aug 19, 2008 | 07:05 AM
Fisherguy's Avatar
Not sure about 2WD's, but on 4x4's there's a couple spacers between the axle and the springs, removing them should lower the rear about an inch.
Old Aug 19, 2008 | 10:07 PM
No blocks on the 2WD.
Old Aug 20, 2008 | 07:44 AM
Ram Daddy's Avatar
Doesn`t someone make a shackle lit to lower the rear of a 2WD 2500?
That truck looks SWEET
Old Aug 20, 2008 | 10:49 AM
FourX4Fabber's Avatar
325 toyo's
325's toyo's no lift or level kit, stock suspension, slight rub on control arms at full lock
Old Aug 21, 2008 | 02:16 PM
I believe so. But I was thinking of putting airbags on it for when I tow and I heard that if you lower it first you have to notch the frame to put airbags on it. I do not want to notch the frame.
jimbo486
13
Nov 5, 2009 09:17 AM
467echo
May 31, 2009 05:12 PM
txfiremedic
Sep 30, 2007 11:57 PM
megadiesel
May 7, 2007 10:58 PM
97CTD
Feb 24, 2003 05:00 PM
