Nitrous + Meth = ???
Anyone running nitrous with high concentrations of meth? When racing I currently run 50/50 and it works great for me. Should I cut back the meth when on the spray? Maybe 30 or 20% or none at all? The nitrous will be pre-CAC and a rather small shot (for now) just to try and light the turbo off the line and get me better 60'ers.
The only reason I am afraid of running 50% meth or higher with N2O is Meth is flammable over 50% and N2O being a oxidizer could be inviting trouble. I know I stand a good chance of lifting the head off the deck but that comes with the territory. Thanks for the replies!
actually its propane and meth you want to stay away from.
I was trying to find a write up on W/M and N2O but cant find it now. I do remember them saying they did not recomend mixtures above 49/51.
matego,
Easy on the meth...Water is fine.
The more fuel you run the less meth you should use....Nitrous just adds to the problem.
I think a small jet on the air horn is the best place to lite turbos off the line.....You'll be surprised how little nitrous it takes here.
I've found pre-cac to be a less responsive on the line, but more forgiving for peak hp.
I would run a second stage (boost referenced) pre-intercooler...Just enough to clear the smoke.
Running a button on a stick is a sure way to get a lean backfire.....Go boost referenced.
Just curious, but do you build boost at the line with your e brake?
I know XLR8R runs N2O and meth but I dont know if they are both together. In gassers its no big deal but I want to know for sure.
I think for now I am going to run the N2O on a pressure switch and have it kick out at 20-25PSI. I will then turn on the water/meth at that point. The meth helps out the top end a lot and its burning clean and cool at the 1320 so I doubt N2O would benefit me there anyway. I really need the turbo to light in the 60' range and hopefully a .051 shot will do it.
I just came back from a exciting day at the track. I helped a guy get his blown 4.6 Mustang from 2.7 60's to 2.0's on street tires with a few tricks. Even with no traction he was running 12.2's at 129.xx and I was running shotgun helping him out. It was his first time at the track and pretty much the first time he drove the car like that. I forgave him for having a Stang and gave him a helping hand.
No, I tried that and it was not very productive for me. I wick the throttle to maintain 8-10 PSI boost and let her rip. I have been able to get 1.82-1.90's doing it this way but after reviewing some tapes I spin a lot off the line. I am probably going to invest in some decent track tires too.
So I should run a small shot in the intake horn? I was ready to run it pre-CAC as others have suggested but it makes sense that it does not have to travel far to get to the fire. I really dont need it for cooling but more for getting the raw black goodness cleaned up.
I have made my mind up to run the N2O until 25 PSI boost then work in the meth. I dont want to blow something up running both at the same time.
Mike D
87
Apr 10, 2008 03:18 PM
Coal Train
26
Jun 20, 2007 09:05 AM
3500lly
Feb 6, 2007 11:07 PM
chw
13
Dec 23, 2006 06:08 PM
