manual trans
Old 11-12-2014, 10:08 PM
Ray1's Avatar
manual trans
I know there are /were 2 different manuals made .
Don`t know model #`s but reverse on one is upper right and the other is lower left .
Is one better than the other?
Thanks,
Old 11-13-2014, 07:41 AM
jhenson's Avatar
The NV5600 is cast iron and the G56 is aluminum. Reverse on the 5600 is to the right and up....to the left and down on the 56. I prefer the stoutness of the 5600 but parts are a bit hard to come by because its no longer produced.
Sent from my paperweight
Old 11-13-2014, 12:02 PM
Jeff in TD's Avatar
The NV runs in MTL where the G runs in ATF. Stock, the G has a dual mass flywheel where the NV came with a conventional flywheel. Early G's had a much lower high gear than the NV.
I've had one of each, and neither have caused problems.
Old 11-18-2014, 03:30 AM
Steve-l's Avatar
The NV is super strong and tough. Failures are rare. They are large and very heavy. They shift well, just not as fast as the G. I would think that the very low failure rate contributes to the availability of spare parts.
Old 11-18-2014, 05:44 AM
Jeff in TD's Avatar
I think their having been discontinued is what makes parts difficult to find and high priced.
Personally, if I were shopping for a stick truck, I'd consider its overall condition and price first, and wouldn't necessarily turn down either transmission.
If you were wanting to do some sort of competition, high power build, then maybe look specifically for an NV?
Old 11-25-2014, 10:33 PM
Ray1's Avatar
Thanks
for your answers.
I had an CTD with an auto before , want to get another but though a stick might be fun . But i have in CA. where it`s a parking lot on the fwy and don`want to wear out the clutch or my knee.
Old 11-26-2014, 12:29 AM
Jeff in TD's Avatar
If I were going to get an automatic, I'd probably put up with the emissions stuff and lower mpg of the newer trucks in order to get one of the 6 speed autos.
Free89W350
12-28-2011 11:18 AM
badzj999
08-20-2010 05:17 PM
fpr01
09-21-2008 11:31 AM
djgaston
10-30-2005 03:18 PM
ezdemon72
14
07-29-2005 10:05 AM
Quick Reply: manual trans
