Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-11-2012, 10:44 PM   #1
td3620
td3620's Avatar
Question Airdog fuel system
i bought this very clean 01 dodge diesel,he put an air dog fuel system on it.well i hear nothing but good things,but im having problems with it.I got to 1/2 a tank of diesel and it was sucking air,and i was on a slight hill,,but the first week i had it,i got to a 1/4 of a tank until i had to get diesel.do i need new fuel filters,Please Help me thank you.since air dog cant answer me back.
td3620 is offline   Reply With Quote
Old 06-11-2012, 11:41 PM   #2
JARHEAD
JARHEAD's Avatar
I feel your pain. Does it have a draw straw V on it? Someone had posted not long ago that the clamps used on the DSV tubing inside the tank sometimes dont do good enough and some guys have had problems with sucking air when about 1/2 tank or less.
2007 2500 Quad Cab, Laramie, 4x4, short bed, stock
JARHEAD is offline   Reply With Quote
Old 06-12-2012, 04:17 PM   #3
td3620
td3620's Avatar
i dont know.what to look for.where do i find it
Old 06-12-2012, 04:59 PM   #4
JARHEAD
JARHEAD's Avatar
It is inside your tank. That is one possibility.
Old 06-12-2012, 05:01 PM   #5
JARHEAD
JARHEAD's Avatar
No way to check that without dropping the tank. Maybe someone else will have some better advice to add.
Old 06-12-2012, 05:38 PM   #6
dkenny
1/4 or 1/2 tank as measured by the gauge?
is the gauge right?
-dkenny
'99 dodge ram 2500, 4x4, auto. 4" mrbp turbo back, Air Dog 100, fuel pressure, boost and EGT gauges
'06 jeep liberty
'84 Detroit diesel 8.2L turbo..blue bird school bus->no longer. tranny died(4/11)
dkenny is offline   Reply With Quote
Old 06-13-2012, 05:02 PM   #7
td3620
td3620's Avatar
yes the gauge is right, and first day i got it got to 1/4 of a tank and i had to find gas station,now when i get to a 1/2 a tank it starts to suck air when i try to start it.i have to put pedal to floor to get it started
Old 06-14-2012, 08:34 PM   #8
dkenny
I ask only because these truck have a know problem with the fuel sender..
I should have taken a picture on mine this am..read 'E' and the light was on..but when I turned it off the night before it was just under 1/2...
so is the gauge right?
at lunch today it was reading just under 1/2 tank..I didn't touch anything..just drove..
so is the gauge right??
did you measure the level in the tank manually? why did the problem level change from 1/4 to 1/2 tank? or is the gauge not reading right?
so when it start to suck air how much to put in the tank? 15 gallon or 34?
-dkenny
Old 06-14-2012, 08:41 PM   #9
HOHN
HOHN's Avatar
My fuel sender has been failed for about 6 years.
Given the high cost of replacement and the likelihood of another failure, I just decided that a trip odometer was a useful substitute.
Justin
Mechanical Development Senior Engineer, Cummins Heavy Duty Engineering
** Opinions expressed are mine alone, and NOT the official position of Cummins, Inc., or any affiliate or subsidiary.**
HOHN is offline   Reply With Quote
Old 06-17-2012, 10:21 PM   #10
td3620
td3620's Avatar
yes my gauge is right.it works fine.
Old 06-23-2012, 12:14 PM   #11
duster75
duster75's Avatar
take fuel line off and verify your problem by cycling key to start pump. Look at top of tank and verify that your fittings are not crackedor leaking. Keep truck 3/4 full so it cant suck air. I'm betting its the fittings on top of your tank. Its a push in to pull line off type deal and the steel "neck" gets rusty and fails....thats why I installed a draw straw and new sending unit as mine was off also.And when installing a straw you have too make sure your staw is cut to length and not too short. I did mine in trk lifted bed off.
"99" w2500 std. cab stock cummin's 5spd,Refection's cowl Ind.hood, 2 tone purple and silver, Debadged,Yea its a 53 block,4wd act. replaced, lukes link, Bilsteins 5100's, 285/75/17 Toyo's MT's on "03" stock alloy's,silencer ring mia, LarryB's starter fix, Big line kit and air dog 100 $15 fuel pressure gauge, vulcan drawstraw1,V.P dead at 104,000 Blue Chip X V.P installed K.D.P fixed,Now 3Rd gear sincrows gone at 110,000 miles WHAT NEXT?????
duster75 is offline   Reply With Quote
Old 06-28-2012, 05:08 PM   #12
td3620
td3620's Avatar
thank you
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
