Help 05 with no power!!
Old Sep 1, 2010 | 02:35 PM
iweb's Avatar
I have a friend with an 05 that blew the plastic inter cooler and even tho he was over 100k miles it was covered under warranty. He tried to get them to change it at 20K miles before it blew and they would not.
Old Sep 3, 2010 | 01:33 PM
thenrie's Avatar
WAIT!!!!! Before you do any of that, disconnect your Edge and clean all the connections. Use a bit of fine emory paper to clean them. Also pull the MAP sensor and clean it with brake cleaner. Just spray it off well. Then reinstall everything, clear the code, and try again and see if that doesn't clear it up. That is a very common occurrence with most programmers. There are a number of threads on that same problem.
If the problem reoccurs, disconnect the programmer, clear the codes, the run stock for a while and see if it happens again. If it doesn't, the problem is with the programmer, most likely in the wiring (ie, connections).
The problem is that bad connections or a dirty or bad MAP sensor is sending out an erroneous "low manifold pressure" signal to your ECM, which then shuts down your turbo (simplified explanation).
Apparently, just my assessment, the additional wiring and circuitry of the programmer increases the resistance in the MAP circuitry to the point where it is barely within spec, and any additional resistance from a dirty sensor or poor connections, decreases the voltage (increasing resistance decreases voltage, ECM codes trigger on voltage drops/increases) to the point where the ECM thinks it is reading a bad MAP sensor.
I was having the problem and traced it to a bad connection to the MAP sensor. I replaced the connector, cleaned all the connections and the MAP sensor, and just made a 5,000 mile trip with no problems.
Old Sep 7, 2010 | 10:49 PM
Sandaholic's Avatar
Question
You post in the right thread there pal? Dude has a leak in his intercooler
Old Sep 8, 2010 | 06:47 AM
thenrie's Avatar
Originally Posted by williams1981
Ok so i pulled the boots off and looked at the turbo, well at least i think i know what i am doing...I pulled everything off on both sides of the intercooler, everything was tight. And looks good, the wheel on the compressor looks fine, no play and it spins fine, i put a rag in the one side of the intercooler and used i bike pump...only thing i have at this moment... I pumped and pumped and it goes up to 5psi and it won't hold anything, problem is i can't pump fast enough to find the leak...any suggestions? besides buying an air compressor? :-) Thanks.
Well, I think I read all the posts before I posted. What I saw was that he checked the intercooler and found it OK. The code he's throwing is a common problem with programmers.
Old Sep 8, 2010 | 06:48 AM
thenrie's Avatar
Well come to find out, the plastic side on the passenger side has separated. So now comes the fun part of a little R&R. Also the question is what should i replace it with, I found a BD intercooler that was 1000.00, does anyone know if this is a good intercooler???. Any suggestions would be helpful however i am not looking to spend to much money... Thanks for all the help guys!
Oops! I missed that one. Sorry. You're right.
Old Sep 8, 2010 | 02:32 PM
Sandaholic's Avatar
You had me thinkin' I had missed something!
williams1981 you your IC replaced yet?
thanasi
Jan 15, 2007 09:53 AM
powerwagon440
Jan 20, 2003 08:50 PM
pwabbott
14
Dec 20, 2002 08:23 PM
Garz
Nov 17, 2002 02:02 PM
