6x16 injectors
Old Feb 1, 2010 | 10:33 PM
SmokemS's Avatar
6x16 injectors
where can i get a a set of 6x16 injectors from?.....when i go pick my new truck up...i wanna get these injectors with a S300 turbo....sound good?
Old Feb 1, 2010 | 10:41 PM
schamran's Avatar
scheid?
Old Feb 1, 2010 | 10:48 PM
TrkEnvy's Avatar
its gonna be dirty with 6 X 16s but thats what the big boys run from what ive heard. Hope you like smoke
Old Feb 2, 2010 | 05:47 AM
JD730's Avatar
Thats a fact. The only time mine didn't smoke with 6 x 16's was when I shut it down. 6 x 16 is the smallest injector recomended for a 14mm head and rotor.
Scheid or budda diesel would be a good place to get them made. Go over to 1stgen.org and check out all the big injector threads over there.
Which S300 are you thinking about? From experience a 62/65/12 is too small for those injectors with a maxed 12mm pump. A 62/71/?? would be a better choice.
What are you going to do about the drivetrain? Clutch or transmission, because they have no chance of holding that kind of power in stock form.
Old Feb 2, 2010 | 07:48 AM
dzl_damon's Avatar
I think Richie has 6x16's in his extended cab with stock clutch? IDK maybe he doesn't have a stock clutch. His pump isn't maxed though. Probably pretty mild since he's putting 300hp to the wheels.
They are hazy at idle sadly. Then again, so are my DDP III's but I'm hoping this is a seperate issue for another thread...
Old Feb 2, 2010 | 08:19 AM
Josh bought a clutch in his other truck, He'll just have to buy a little more for this truck.
Good luck with the new truck Josh , post pics when you get it
Old Feb 2, 2010 | 08:38 AM
Richie O's Avatar
366 Spring Chicken
Yup, stock clutch, yup, mild tune, and its 301 hp, not 300.
PToombs went as far as 388 hp on his stock clutch. He slipped it a few times trying to shift hard so he updated. My clutch has never slipped but I don't apply power while engaging it. Only wide open after its hooked up. Mine do haze and can be smokey at low boost. At my current tune its 44 to 45 psi boost on a 16cm with 60 gds H1C. I suspect with a high end turbo I would see 38 to 40 psi at same fuel level. ( less drive pressure )
Old Feb 2, 2010 | 11:42 AM
archer39's Avatar
coaltrain diesel will make them for you. That is who i got mine from.
Old Feb 2, 2010 | 11:52 AM
dzl_damon's Avatar
I forgot! You must have put on a racing sticker or headlight covers to get that extra 1hp!!
Old Feb 2, 2010 | 12:20 PM
92smokin blacky's Avatar
I think any big injector is gonna be dirty and haze, especially if your pump is maxed. I know my truck does with just PODS and no afc, I can't wait to go bigger though.
Josh go big and throw some 6x18s and a twin setup in that beast
I have heard nothin but good stuff about coaltrain injectors and thats who I wanna go through when i upgrade to bigger sticks once i get a tranny and more turbo. I've also heard good things about scheid and New Era. I don't know what Industrial Injection has for 1st gen injectors, haven't really checked with them, but i would check with all those companies and see.
Old Feb 2, 2010 | 01:43 PM
Richie O's Avatar
366 Spring Chicken
Is coaltrain still in buisness?
Old Feb 2, 2010 | 01:46 PM
Richie O's Avatar
366 Spring Chicken
No, my boy was in the truck with me and he was helping push the pedal down. He was all nervous ( 9 years old ). He's like " Im not supposed to be in the truck ".
I have noticed my 89 with stock sticks now haze also since that pump is putting all it can out. It never used to haze at idle before I got crazy.
Old Feb 2, 2010 | 01:58 PM
poor 727
Old Feb 2, 2010 | 03:26 PM
SmokemS's Avatar
thanks for all the info.....if i'm gonna go big i should do it all at once and i'll have to cash to do it......but i am gonna upgrade to the southbend DD.....that should hold those injectors right?
Old Feb 2, 2010 | 04:12 PM
93Fury's Avatar
J-L Machine supposedly does 6x16's and so does SDX. I haven't heard much about either but I know people that have dealt with SDX and very impressed with the company.
I would sure hope a SB DD would hold them.
