High idle after using cruise on interstate
Old Nov 20, 2009 | 09:07 AM
ted_pulliam's Avatar
I notice that my idle increases by 75 or so rpm after a run down the interstate at 65 - 70 miles per hour with the cruise set.
When I stop the engine and restart it the idle drops back down until the next time I use cruise.
What could be causing this?
Ted
Old Nov 20, 2009 | 11:31 AM
rebal's Avatar
mine will go up 100-150 after a long run on CC. its sorta strange but has not left me stranded I dont know if its in need of a reflash or what, but I wont take my truck back to the dealer for nothing. my truck is not stock anymore.
Old Nov 20, 2009 | 12:42 PM
thanks rebal. I won't worry too much about this since the truck runs good otherwise.
Ted
Old Nov 20, 2009 | 08:53 PM
SWC's Avatar
SWC
When I had this problem the Pacbrake would not engage. This all tied into the APPS going out on me. If you have no other problems don't worry about it. I found away around the exhaust brake problem and put up with the idle issue for 4 years. When I started having dead pedal issues on a trip I replace the APPS and everything is fine now.
Stan
Old Nov 24, 2009 | 12:40 PM
ldornak's Avatar
x2 on the APPS. I had the exact same issue - high idle after using cruise. I replaced my APPS and the problem went away.
Old Nov 27, 2009 | 11:07 PM
sheriffav8r's Avatar
It's totally normal. Do a search on it an you will see that the PCU/ECU has numerous idle speeds based on countless paramaters. You're experiencing the "cruise idle" that happens sometimes after cruising at highway speeds....
Old Nov 29, 2009 | 12:19 AM
Captain Coop's Avatar
Had the exact problem however mine would idle to almost 1200 RPM. Mine was the APPS and after replacing it that stopped but it would still idle up just a little bit after cruise was engaged for a while or just after running at highway speeds for a while. That is normal. Ive heard that its something to do with all the sensors readjusting and it just takes a second??? but it is normal.
Old Nov 30, 2009 | 09:08 AM
Thanks everyone. I can live with the high idle for now :-)
Ted
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
DUKCALN
23
Dec 17, 2008 09:21 AM
jmccart
Jun 12, 2007 02:12 PM
6 2 Carl
Sep 22, 2006 01:00 PM
