I got my Goerend Valve Body today!
Old Nov 16, 2009 | 06:56 PM
AEmedic's Avatar
I got a Goerend Valve Body and what I think is a Strap and anchor kit. Can any one provide a picture of the kit?
I had the trans built in TX but failed to get a Valve Body, instead I got the Trans Go shift kit that just didn't work out. I hope to have it put in soon!
Old Nov 16, 2009 | 07:42 PM
BigDogJeepin's Avatar
What problem did you have with the Transgo?
Old Nov 16, 2009 | 07:46 PM
AEmedic's Avatar
I had a valve body failure and severe 1 - 2 shuttle shift. I am currently running a stock VB and it is very smooth, but not where I want the trans to be...
Old Nov 16, 2009 | 08:03 PM
The reason I ask is I am installing the Transgo on Wednesday.
You can see billet parts on this site, scroll down near the bottom:
http://www.transmissioncenter.net/dodge.htm
That would make sense that those parts come with a valve body but i'm surprised that they didn't include a front servo cover with it. The stocker apparently leaks fluid at the higher line pressures.
What is valve body failure?
Old Nov 16, 2009 | 08:15 PM
AEmedic's Avatar
The shop didn't tell me how it failed exactly, I believe it was cracked somehow, possible by how it was modded during the trans go install.
Old Nov 16, 2009 | 10:00 PM
1985cucv's Avatar
sounds like they installed something wrong!
Old Nov 16, 2009 | 11:02 PM
no_6_oh_no's Avatar
Now, check out the replacement VB and see if it is a 48 or a 47 model. Depending on how it was built and your trans was built you may have some issues getting things to work correctly.
Old Nov 17, 2009 | 05:54 AM
AEmedic's Avatar
The Goerend was shipped from them directly, the only issue was that they wrote 2005 on the sheet rather than 2006. I called and asked and they said it makes no difference. I agree though, I hope it plays well with the trans...
Old Nov 20, 2009 | 04:46 PM
AEmedic's Avatar
I got the VB, strut and anchor installed today. I added a bottle of Lube Guard and it shifts nice and firm but not harsh.
Now all I need to do is figure out a trans temp gauge and I'm all set.
GlennRMK
Jun 1, 2008 01:52 AM
blwnsmke
23
May 12, 2008 07:51 PM
blwnsmke
28
Apr 3, 2008 09:06 AM
Ilikebikes
Nov 17, 2006 09:36 AM
Bobcat698
Jul 24, 2005 09:24 PM
