CTD in '85/need brake booster?
Old Oct 25, 2009 | 06:07 AM
I just bought a crew cab that has been already been converted to CTD power. The brakes work but it reminds me of my manual brake powered '69 Cuda. I have to stand on the brakes to get them to work and no matter how hard I stand I can't get the wheels to lock up. I am thinking that the brake booster is a gasser job. Would putting a "diesel" brake master and booster be the set up I need? Those gas boosters work on engine vacaum right? The brake lines and brake calipers, pads and shoes where changed by the last owner as I am sure he was trying to make it stop better.
Any ideas guys?
Thanks
Old Oct 25, 2009 | 06:42 AM
JD730's Avatar
I would seriously consider switching to a hydro boost system instead of vacuum. I've had issues with the vacuum systems on 2 of my 93's. One I switched to hydro boost and other I'm starting to gather parts for.
Here's a little reading on the subject.
https://www.dieseltruckresource.com/....html?t=169715
Old Oct 25, 2009 | 09:13 AM
rich's Avatar
hydroboost is the way to go, gm has been doing it in their 3/4 and up trucks since the mid 70's its way better then vacuum
Old Oct 26, 2009 | 06:26 AM
I don't want to do something just cause GM did! LOL. I just can't belive that this is the best this brake system can work as it is un-safe in a panic stop. I can't get the wheels to lock up even on dirt and as an auto I am also fighting the engine! I will check the vacuum line to to see if it is cracked or broken. I will look at the hydro boost system as I have a few '94 and up parts Diesel Dodges I could steal the parts off of.
Old Oct 27, 2009 | 09:01 PM
Trooperthorn's Avatar
If you don't want to go with the hydro, just get the parts in there that were with the diesels in the first place. Put premium pads and shoes on it and turn the rotors and drums to remove the glaze. You should be good.
Old Nov 5, 2009 | 09:13 AM
So I am looking at swapping the brake booster and master for a diesel job out of a 1st gen Trooperhorn? That sound easier than swapping in parts from a different gen truck.
Thanks
kc8ksg
Mar 8, 2006 09:47 PM
sgT
Nov 30, 2004 01:54 PM
seedy1
Oct 20, 2004 10:50 AM
Crimedog
Oct 9, 2004 09:05 PM
betsycam
Aug 17, 2004 07:34 PM
