conversion cummins to ford with a dodge cab
Old Mar 12, 2008 | 12:21 AM
Alwaysworking's Avatar
alwaysonDTR
well i'm starting my conversion.which is strecthing a 85 ford cab and chasis 4x4 duallly and putting a 82 dodge crew cab on thatand putting a cummins in that. i have the frame and the cab -1 rear door (drivers side) and i have the 92 cummins with a getrag plus i just bought a industrial cummnins core(has a bad crank and no water pump) rated at 152HP with no afc on the pump.
so i need to find a water pump, whats a good place to find one? and what should i expect to pay?
i also read that there is an upgraded heater core for these 92 dodge trucks? if so where do i find one?
would it be better to run the industrail injection pump? also the 92 has upgraded injectors but i dont know what they are.
Old Mar 12, 2008 | 02:31 PM
alwaysonDTR
what the cab looks like
Old Mar 12, 2008 | 02:45 PM
PapeCAT's Avatar
Sounds like a good project, but if you weren't going to 4x4 I'd stay with the dodge crewcab chassis. Inspect it when you get the chassis off, it is very beefy
Old Mar 12, 2008 | 04:20 PM
Most any parts store can sell you a water pump.
Don't use the industrial injection pump.
Old Mar 12, 2008 | 04:28 PM
pwrtripls1's Avatar
the water pump should be around $30
Old Mar 12, 2008 | 09:53 PM
alwaysonDTR
what is different about the industrial injection pump/why shouldn't i use it? just woundering, i will use the stock cummins one.
i would even stick with the dodge frame if i had wider runing gear.
Old Mar 12, 2008 | 09:54 PM
alwaysonDTR
is that with the pulley, because that is all i am missing.
Old Mar 12, 2008 | 10:08 PM
bloodhound51's Avatar
yes the pulley comes attached to the water pump.
you are using a ford chassis with the dodge body. right?
Old Mar 12, 2008 | 10:24 PM
alwaysonDTR
yes ford chassis with dodge cab
Old Mar 12, 2008 | 11:10 PM
haha cool conversion havent seen one yet.
Old Mar 12, 2008 | 11:17 PM
alwaysonDTR
the fun part is the frame strech ford is standard cab and the dodge is well alot longer. but i have a cnc plasma and torch so the fish plates will be easy.
Old Mar 13, 2008 | 12:01 AM
farmer0_1's Avatar
trooper thorn may have a door to sell you off his spare parts.
Old Mar 13, 2008 | 12:12 AM
alwaysonDTR
thanks, i pm him. i hope to see his convertion driving around salem soon.
is there a way to get better heat out of the heater core. i need it to clear all the windows or at least most of them
Old Mar 13, 2008 | 12:56 AM
alwaysonDTR
also it will be a hoist bed, and i going to run stacks
Old Mar 13, 2008 | 06:22 AM
ofcmarc's Avatar
Aftermarket heater cores are thicker than stock and put out more heat than the stock one.
