dead pedal, 0216, whats going on?
Old Jun 18, 2007 | 11:12 AM
turbo dreams's Avatar
i have been having dead pedal a couple of times now. usually going down the raod once i am in overdrive. i try to accelerate to go up a high and nothing happens. i have top shove the pedal to the floor to finally get the tranny to downshift and go. no CEL. pulled codes anyway and got the p0216 twice. the vp has less than 50k on it. i changed it a year and a half ago. the truck starts fine and runs fine until i cruise for a little while in overdrive then i get this dead pedal. last time my pump dies i was getting hard start issues and it would surge when i put in in drive from park. therefore i am not quite sure it is the pump. could it possibly be another sensor which is going out that is altering the pumps performance? do these trucks have a throttle position sensor or is it the apps sensor? what does it do? how does it work? where is it located and how much do they run? thanks
Old Jun 18, 2007 | 12:07 PM
graphitecumnz's Avatar
Sounds like another VP-44 is in your future...
Old Jun 18, 2007 | 01:19 PM
i seriously hope not. this is getting pathetic now.
Old Jun 18, 2007 | 08:02 PM
Having had both a VP-44 and an APPS go south, they were completely different symptoms. Your description is what my truck did for about 6 months as I nursed it to a complete and totally dead VP-44.
You list a Carter as a pusher, does that mean you are still plumbed into the factory pump as well??
Old Jun 19, 2007 | 01:22 AM
camelracer's Avatar
I had the same problem at just over 50k miles. Two dead pedal incidents and a P216 code. Except for that the truck started ran fine. The fuel pressure has always been good. The dealer replaced the VP44 under warranty.
Old Jun 19, 2007 | 06:52 AM
fwiw, fuel pressure isn't the end all in VP-44's life... you also need fuel volume.
Old Jun 19, 2007 | 07:13 AM
blackdiesel's Avatar
Registered
I've had two different VP'S last less than 10k (on two diff. trucks), so your's lasted 5 times long than those two did. Fuel pressure and volume are just two things that can shorten the life of a vp, but they can, and do die, just for the fun of it.
Old Jun 19, 2007 | 07:23 AM
that makes me so sick. i can assure you this is the last pump I will replace. truck is going after this. i was told though that the tps might be the cause. it has similar symptoms.
Old Jun 19, 2007 | 04:21 PM
Registered
I would think it would have a APPS code if that was the case.
Old Jun 19, 2007 | 05:46 PM
I don't think I've heard of too many APPS resets/replacements clear a P0216.
There is a good writeup on Blue Chips website about VP44 failures... it's a must read.
Old Jan 31, 2010 | 03:10 PM
stonewalldiesel's Avatar
Been through this a few times now. First time it happened I thought right off that it was the VP44. A year later same thing but what was strange is if I turned off the truck and restarted it was fine. Again it happened and this time I noticed my edge comp box was flickering. I shut it off and worked fine. I started researching and noticed the problems started when I had my comp box upgraded to hot. I have had 3 different boxes replaced by edge and this last time I had thenm set it up back to Comp only. I believe all of my problems were related to the comp box. I bought a rebuilt VP44 the first time and I blieve there was nothing wrong with it. We shall see if this works.
Old Jan 31, 2010 | 03:44 PM
Copenhagenjunkie's Avatar
You could try the apps recalibration method, it's free.
https://www.dieseltruckresource.com/...65&postcount=9
Did you change the lift pump when you installed a new vp-44?, Do you have a fuel pressure gauge? It is likely that your vp is dieing again if you answered no to the questions.
Old Dec 17, 2018 | 09:53 PM
KATOOM's Avatar
Check the alternator output for AC voltage levels. If they get too high from diode issues then the AC voltage can cause all kinds of phantom issues, affect the auto transmission solenoid and torque convertor locking, and damage sensitive components like the PSG, ECM, and PCM. If you're uncertain of what to do or look for just ask...
Old Dec 18, 2018 | 08:45 PM
PaulDaisy's Avatar
This thread is 10 years old.
Old Dec 18, 2018 | 10:24 PM
KATOOM's Avatar
HAHAHAHA..... You're right!!! Not sure where or why I came across this thread.....and not sure why I even responded to it either. Lets hope the problem was resolved by now.
And for crying outloud some moderator close this.
600 Megawatts
Mar 26, 2008 07:09 PM
R.T.D.H.S.P.
Aug 22, 2007 08:09 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
HOdiesel80
Jun 10, 2005 07:53 PM
