#16 |
Since I inheritied I don't drive alot and never heard of that?
__________________
2003 2500 SLT Quad Cab 4X4 Long Box SO 5 SPEED Grand Rock Stack Kit w/ 6" miters, AFE Magnum Force w/ Torque Tub, TST PowermaxCR, GDP 392, SBC DD 3600#, Upgraded input shaft, Ride Rite Air Bags, B&W TOB, B&W Companion 5th Wheel. II rebuilt injectors with 60 HP tips. Recent Additions: 99 2500 4x4 SLT Extended Cab, long box, 5 speed, K&N, Muffler MIA, 321k and counting 96 Freightliner M11 Cummins, 310hp, and Eaton 10 Speed, Single Axle, Cab Over. 32' Cardinal 5th wheel. |
#17 |
The trailer helped him alot. Guess they really are designed to have some weight on them. Then we practiced down shifting and the jake on high really screwed him up, but the trailer was empty. Not winding it as tight seemed to really help. thanks again.
#18 |
Forgive me for a possible ignorant question. But why should you use the clutch? I have driven many 10 speed Eatons and never use the clutch. Infact I have operated a 330 Pete almost daily for over 4 years without clutching between gears. It seems like once you learn how the truck drives, the gears simply fall into place. No grinding etc. I have been driving for 15 years and was self taught, so I could very well be doing something wrong. Now that I think about it, I can't remember a time that an experienced driver has ever riden with me. Thanks for the advice.
__________________
95 2500HD SLT Laramie X-Cab 4X4 296K 47rh, Triple Disk TC, VB Upgrade, 3.55 gears, #11 FP, AFC Full Forward, Disabled Wastegate, K&N Air Filter, Guages, Dead KDP, Chevy Rear Wheel Cylinders, Straight Pipe + Glass Pack, Kool-vue Towing Mirrors Towing: 10K 5er and snowmobiles, on occasion both as doubles |
#19 |
He is just learning his self and I only use it when i screw up to take the touque off. All he had ever driven was gas trucks and a few of our trucks and not very well with the standards. My duel disk still give him fits.
#20 |
Ok thanks. Just wanted to make sure I wasn't doing something wrong. Hope he gets the hang of it soon.
#21 |
is it a super 10 tranny??
#22 |
i hate those super 10s and the 10RTO
__________________
00 3500 4 door, 2wd, dually, 5 speed, with D80 with 3.54, Raptor fuel pump, 1/2 lines with boost, EGT and FP guages and Quadzilla Adrenaline, home made intake, silencer ring uninstalled, and home made boost controller. 4 inch DP with 5inch exhaust |
#23 |
I seem to have that problem when operating machinery!
__________________
SOLD!1992 Dodge 3/4 ton CTD 4X4. 4" exhaust. Bosch 190 injectors. 3200 RPM governor spring. K&N. Pump turned up. Timing bumped. 12 cm wg housing. Pyro, boost, tranny temp and tach. Hughes torque converter. 137K. Homemade grille gaurd. SOLD! 1994 Dodge 3/4 ton CTD 4X4. 5-speed. Flatbed. 254K. SOLD! 1998 3/4 ton 12 valve 5-speed shortbed quad cab 4X4. 2004 Dodge 3/4 ton 4X4 6-speed no options just like I like it! Stock cept for the 3.42 swap. South Dakotan stuck in KS! |
#24 | |
program or owner truck
Quote:
you can talk to dealer and they will give you practical rpm range for specific engine unless you have some fuel saving program installed in the engines computer most problems are generated because of wrong rpm's when shifting |
#25 |
WHen I started driving I had 10 years in our dump trucks already. I teamed with another new guy whose training had all been in a cabover IH. He would come out of gear, flick the lever around, then use the detent to find his next gear. WHen he got in the Century class freightshaker, he couldn't hit a gear, the detent wasn't heavy enough for him. I finally had him hold the top of the lever while I moved it from the bottom of the cap, and floated a couple gears for him. He hit every gear after that.
I drive a 13 speed now, and a 10 screws me up if I have to use one. I never could get a 5 speed spicer. |
#26 |
The faster the countershafts are turning the harder it is to shift. Keep the rpm's lower and it is easier. With a front box od the shafts turn about twice the speed and are therefore harder to shift. Also I have trouble with mine when the trans is cold. I never use the clutch....
__________________
99 2500 4X4 Laramie Quad cab ISB275 engine 660 tq stock with air comp, HX35/18.5, NV5600, 13.125 SBC, 354 posi, Rancho 9000, Scotty II, EZ, FASS, bottom feed, ported ATS ex man, Isspro gages, Truspeed, Ford dual wheels, Jorden, Alpine, amp, M15000 warn. Freightliner Condo, N14 500hp. Kaufman EZ loader VI car hauler 97 Dodge 2500, Club cab, 4wd, tow body, cow catcher, 12v, NV4500 Borne 50’ car hauler 53/102 Trailmobile Reefer |
#27 |
From my exp if a guy can't get "basic" shifting down in one day he never will. Not saying I don't ever miss a gear or scrub one from time to time. Honestly the trans that gave me the most trouble & would refuse to own or drive is that 7spd mack. Two sticks are easier than that thing
. My fav trans are 8LL or a older 15spd. I've rode shotgun with several guys "learning" & maybe 1 out of 5 got to come back to work the next day. Shifting is like running equip you can either do it or not, can't be "taught" ,least thats what my grandpa use to say!
__________________
02 2500 4X4 QC, Full Billet DTT, Adrenaline, FASS, Smarty, 5"ex, HTT 64/14, RV275's "for now" |
#28 |
Ad-meany-strator
I'd have to agree with that. You either have a feel for machinery or you don't. It's not a skill that can be taught to everybody.
__________________
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner. 386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air! "Butterscotch" - '82 Mercedes 300TD Dead KDP's = 72 |
#29 |
On a ten speed, take the rpms up to the point you want to shift, slip it out of gear, let the engine drop 500 RPMs and it will slip right into the next gear, Same way to downshift, just backwards. When the RPMs drop to the level you want to shift at slip it out of gear, raise the engine up 500 RPMs and then slip it into the next lower gear.
On a 13 speed, lower five gears the same as a 10 speed, then there are 300 RPM difference between the upper 8 gears. Use of the clutch is optional, but if you use it, you will need to double clutch. |
| Thread Tools | |
| Display Modes | |
