Shakey Volt Guage
#32
Post #22
You have a voltage drop to the regulator.
Start at the battery and follow the circuit to the regulator. Somewhere in that circuit is the problem.
#35
Just checked, 16+ volts at the battery when running.
Gotta do something!
Gotta do something!
Naw, they are pretty reliable. I suspect you have a problem with a connection or switch (relay) somewhere.
I started to compose a lengthy help text when I realized you actually haven't told us what is happening, other than things are blinking and you are going nuts.
Is it going over-voltage and burning out lights?
Is the voltage going low, ie lights dimming?
What was the PCM code thrown?
It ain't rocket science, but nobody here (I don't think anyway) is clairvoyant.
With some detailed information, actual observation sans feelings, I might be able to propose a diagnostic path to the solution.
Scotty
08-21-2004 11:24 PM
Dieseldude4x4
01-04-2003 03:07 PM
